Measurement Studio for VB6
Want to know the PANTONE color of at a certain pixel of the image
Hi Mohit,
Yes, edge detection cannot work on color images. For a list of operations that support color images, look at the "Supported Image types" in the NI-Vision help.
To convert from color to grayscale, you can use the IMAQ Extract Single Color Plane.vi. The luminance plane conveys intensity information and this will be grayscale.
Jaidev
Senior Product Manager
Message 21 of 27
(6,364 Views)
Than you very much for your help. But I still couldnt convert a colour image to grayscale image becuase I couldnt find the `IMAQ Extract Single Color Plane.vi`, would you like to send the link to open this vi? or could you tell me the location where I can find this vi? I appreciate your help. With regards
Mohit
Berlin
Hi Mohit,
Jaidev
Applications Engineer
Message 22 of 27
(6,353 Views)
Hi Mohit,
Here's how you would navigate the Function Palette:
Vision and Motion>>Vision Utilities>>Color Utilities>>IMAQ Extract Single Color Plane.vi
Also, the function palette has a search feature; look for the Search button in the top right corner. It searches the palette by keyword and then by double-clicking the result, you can see where the VI is.
-Jaidev
Message 23 of 27
(6,337 Views)
hello,
Thank you very much for your tips. Finally I made vi that convert any colour image into grayscale one. for your reference i have attached it herewith. NOw I have to generate code or make vi that will compare one particular image with many other images and find out with which image the  former image is matching. For that, may be I need to define images in terms of line with specific slopes and lengths, and all curves in terms of radius and center. Then if the length and slope of any two lines are almost same, vi should tell us that these two parts match with each other. For your reference i have attached a simple image (png file) where 'A' is reference part and we have to check which one (B or C) fits over A. If I can get some help from you, I would really be grateful to you. please tell me if I have to define my problem again, if it is not claer here.  with regards
Mohit
Berlin
Message 24 of 27
(6,203 Views)
Hi Mohit,
We have Geometric Pattern Matching VIs in the Vision Development Module that do exactly what you are trying to do. Just look up Geometric pattern matching examples in the Example finder to see how they are used. These examples are pretty well documented and should be fairly intuitive.
How to find the examples:
Navigate to Help>>Find Examples... and then navigate to Toolkits and Modules>>Vision. Both the Functions and Applications folders have Geometric matching examples.
Jaidev
Message 25 of 27
(6,190 Views)
hi can plz help me out.....i want to show grayscale images into Bitmap (0-7 bits). Is it possible to show garyscale image into bitmap 1 bit, 2bit,..upto...7bit image.
Message 26 of 27
(4,028 Views)
Please post this in a new thread since this thread is five years removed from activity. You should post your question in the Machine Vision forum since it is dealing with image processing.
Blake C.
www.ni.com/support
Message 27 of 27
(4,017 Views)
