Measurement Studio for VB6
VBA dll labview Array
I created a function in LabVIEW, and I  call it  from VBA ( Access in my case , but it would be the same from Excel). The idea is to pass parameters , and get back an array.
In the option of communicating with the function in VI , I have no problems, but when I compile and I try it with a  dll, It doesn´t work.
I´m only able to use double or integer parameters, but when I try to pass an array or cluster, I´m not able.
In the zip, it is the labview project , and two dll created differently ( in the word there is an explanation of both possibilities)
I have also added the Access to see the VBA code .
Anyway , I copied the VBA code :
Private Declare Function Salvar Lib "C:\ComunicacionVBA\SharedLib.dll" (ByVal y As Double, ByVal x As Double, ByRef Vector As Variant, ByRef Longitud As Integer) As Double
Private Declare Function Salvar2 Lib "C:\ComunicacionVBA\SharedLib2.dll" (ByVal y As Double, ByVal x As Double, ByRef Vector As Variant) As Double
Private Sub Comando2_Click()
Dim x, y As Double
Dim Vector As Variant
Dim Longitud As Integer
x = 1
y = 2
x = Salvar(y, x, Vector, Longitud)
MsgBox (x)
MsgBox (Longitud)
MsgBox (Vector)
End Sub
Private Sub Comando3_Click()
Dim x, y As Double
x = 1
y = 2
x = Salvar2(y, x, Vector)
MsgBox (x)
MsgBox (Vector(0))
End Sub
Message 1 of 1
(5,120 Views)
