09-30-2008 08:06 PM
I have a loop which runs until one of the tasks finishes. I try to make the chkSaveAOV and the chkSaveV equivalent and would use either of them.
However, I found when I have only the chkSaveV box checked, the AOVInFlag changes to True at the ***** commend, which cause a problem for the loop. This happens even though I'm not doing anything with any of the "Save AOV" function.
What is stranger, this doesn't happen the other way around. I mean, when I have only the chkSaveAOV box checked, the VInFlag wouldn't change during the run.
Could you please look at my code and see what's wrong with it? Thanks a lot!
If chkSaveAOV Then DAQmxErrChk DAQmxStartTask(AOVInHandle)
If chkSaveV Then DAQmxErrChk DAQmxStartTask(VInHandle)
Label13.Caption = "Total bins: "
Do
DAQmxErrChk DAQmxIsTaskDone(PhotBinHandle, BinFlag)
BinFlag = Not BinFlag
If chkSaveAOV Then
DAQmxErrChk DAQmxIsTaskDone(AOVInHandle, AOVInFlag)
AOVInFlag = Not AOVInFlag
Else
AOVInFlag = False
End If
If chkSaveV Then
***** DAQmxErrChk DAQmxIsTaskDone(VInHandle, VInFlag)
VInFlag = Not VInFlag
Else
VInFlag = False
End If
DoEvents
Loop While (BinFlag Or AOVInFlag Or VInFlag)
Best,
Yan
10-01-2008 04:50 PM
Hi Yan,
I'm not seeing anything wrong with the code you posted. Is it possible that there may be a process on another thread running which may be changing this flag? Are you doing a continuous generation/acquisition task? Are you using any callback function?
10-01-2008 09:15 PM
Thank you for replying me!
Yes. I am doing a continuous generation task. But I still don't understand why an unrelated flag would change due the running of this task. The entire code might be too bulky to post here. So I'm listing here all the commands related to this AOVInFlag. Could you please tell me what kind of thing might be affecting the value of AOVInFlag?
Yan
Private AOVInFlag As Boolean
Do
If chkSaveV Then
Else
VInFlag = False
End If
If chkSaveAOV Then
Else
AOVInFlag = False
End If
DoEvents
If chkSaveAOV Then
ReDim AOVInDat(1 To 2 * (SampsPerSec * AcqTime) + 1) As Double
DAQmxReadAnalogF64 AOVInHandle, (SampsPerSec * AcqTime), 0#, DAQmx_Val_GroupByScanNumber, _
AOVInDat(1), 2 * (SampsPerSec * AcqTime) + 1, VsampsPerChanRead, ByVal 0&
If AOVInFlag Then
DAQmxErrChk DAQmxStopTask(AOVInHandle)
AOVInFlag = False
End If
DAQmxErrChk DAQmxClearTask(AOVInHandle)
End If
10-02-2008 09:05 PM
Hi Yan,
I'm still not sure as to why the AOVInFlag is getting asserted. Could we try striping down the code to its bare minimum to see if this problem still occurs. Hopefully, this will help us narrow down the problem. Could you then post this code online so we can have another look at this?
10-03-2008 12:15 PM
OK. Here's the code. Thank you for looking at this messy code!
Option Explicit
Const BuffSize = 20000000 'number of photons to store in buffer
Const SampsPerSec = 40000 'Number of voltage reads/second
Const DARate = 1600000 'Max number of D -> A conversions/channel/sec
Private ReadPhotons As Variant
Private VOut() As Double
Private VCarrier() As Double
Private Vtemp() As Double
Private VMod() As Double
Private VXoff() As Double
Private VYoff() As Double
Private VOutHandle As Long
Private VOutFlag As Boolean
Private SampFreq As Double
Private SampsPerCarCyc As Double
Private SampsPerModCyc As Double
Private SampsPerXoffCyc As Double
Private sampsPerChanWritten As Long
Private sampsPerChanRead As Long
Private VsampsPerChanRead As Long
Private i As Double
Private j As Integer
Private k As Integer
Private ErrVal As Long
Private FocusFlag As Boolean
Private AcqFlag As Boolean
Private BinFlag As Boolean
Dim CtrDat(1 To BuffSize) As Double
Private PhotCtrHandle As Long
Private PhotBinHandle As Long
Private VInHandle As Long
Private AOVInHandle As Long
Private VInFlag As Boolean
Private VInDat() As Double
Private AOVInDat() As Double
Private NumBins As Long
Dim BinDat() As Double
Private CPS As Double 'counts per second
Private VoutCycHandle As Long
Private VCycs As Long
Dim VoutTimes() As Double
Private VcycsRead As Long
Private Sub Form_Load()
DAQmxErrChk DAQmxResetDevice("Dev1")
i = 0
VOutFlag = False
FocusFlag = False
AcqFlag = False
SampsPerModCyc = 200 'For analog voltage out
DAQmxErrChk DAQmxCreateTask("", VOutHandle)
DAQmxErrChk DAQmxCreateAOVoltageChan(VOutHandle, "Dev1/ao0", "", -10, 10, DAQmx_Val_VoltageUnits2_Volts, "")
DAQmxErrChk DAQmxWriteAnalogScalarF64(VOutHandle, True, 10#, XOff.Value, ByVal 0&)
DAQmxErrChk DAQmxStopTask(VOutHandle)
DAQmxErrChk DAQmxClearTask(VOutHandle)
DAQmxErrChk DAQmxCreateAOVoltageChan(VOutHandle, "Dev1/ao1", "", -10, 10, DAQmx_Val_VoltageUnits2_Volts, "")
DAQmxErrChk DAQmxWriteAnalogScalarF64(VOutHandle, True, 10#, YOff.Value, ByVal 0&)
End Sub
Private Sub cmdFocus_Click()
cmdAcquire.Enabled = True
cmdStop.Enabled = True
cmdFocus.Enabled = False
FocusFlag = True
DAQmxErrChk DAQmxCreateTask("", PhotBinHandle)
DAQmxErrChk DAQmxCreateCIFreqChan(PhotBinHandle, "Dev1/ctr1", "", 1, _
2000000, DAQmx_Val_FrequencyUnits3_Hz, DAQmx_Val_Edge1_Falling, _
DAQmx_Val_CounterFrequencyMethod_HighFreq2Ctr, FocBinSize.Value / 1000, 4, "")
DAQmxErrChk DAQmxCfgImplicitTiming(PhotBinHandle, DAQmx_Val_AcquisitionType_FiniteSamps, _
BuffSize)
DAQmxErrChk DAQmxSetCIFreqTerm(PhotBinHandle, "Dev1/Ctr1", "/Dev1/PFI0")
DAQmxSetCIDupCountPrevent PhotBinHandle, "Dev1/Ctr1", True
DAQmxErrChk DAQmxStartTask(PhotBinHandle)
Do
DAQmxReadCounterScalarF64 PhotBinHandle, -1#, CPS, ByVal 0&
CWGraph1.ChartY CPS
DoEvents
Loop While FocusFlag
End Sub
10-03-2008 12:16 PM
Private Sub cmdAcquire_Click()
cmdAcquire.Enabled = False
cmdVStart.Enabled = False
cmdVStop.Enabled = False
chkSaveV.Enabled = False
chkSaveAOV.Enabled = False
AcqFlag = True
If FocusFlag Then StopFocus
Label6.Caption = "Acquiring"
If chkSaveV Then
DAQmxErrChk DAQmxCreateTask("", VInHandle)
DAQmxErrChk DAQmxCreateAIVoltageChan(VInHandle, "Dev1/ai0:1", "", _
DAQmx_Val_InputTermCfg_Diff, -10, 10, DAQmx_Val_VoltageUnits1_Volts, "")
DAQmxErrChk DAQmxCfgSampClkTiming(VInHandle, "OnboardClock", SampsPerSec, DAQmx_Val_Rising, _
DAQmx_Val_AcquisitionType_FiniteSamps, CLng(SampsPerSec * AcqTime))
End If
If chkSaveAOV Then
DAQmxErrChk DAQmxCreateTask("", AOVInHandle)
DAQmxErrChk DAQmxCreateAIVoltageChan(AOVInHandle, "Dev1/ai2", "", _
DAQmxErrChk DAQmxCfgSampClkTiming(AOVInHandle, "OnboardClock", SampsPerSec, DAQmx_Val_Rising, _
End If
If optTimeTagged Then
DAQmxErrChk DAQmxCreateTask("", PhotCtrHandle)
DAQmxErrChk DAQmxCreateCICountEdgesChan(PhotCtrHandle, "Dev1/Ctr0", "", _
DAQmx_Val_Edge1_Rising, 0, DAQmx_Val_CountDirection1_CountUp)
DAQmxErrChk DAQmxCfgSampClkTiming(PhotCtrHandle, "/Dev1/PFI0", 5000000, _
DAQmx_Val_Rising, DAQmx_Val_AcquisitionType_FiniteSamps, BuffSize)
DAQmxErrChk DAQmxSetCICountEdgesTerm(PhotCtrHandle, "Dev1/Ctr0", "/Dev1/80MHzTimebase")
DAQmxSetCIDupCountPrevent PhotCtrHandle, "Dev1/Ctr0", True
DAQmxErrChk DAQmxStartTask(PhotCtrHandle)
If VOutFlag Then
VCycs = (AcqTime.Value * Freq.Value) + 1
DAQmxErrChk DAQmxCreateTask("", VoutCycHandle)
DAQmxErrChk DAQmxCreateCICountEdgesChan(VoutCycHandle, "Dev1/Ctr1", "", _
DAQmxErrChk DAQmxCfgSampClkTiming(VoutCycHandle, "/Dev1/PFI1", 5000000, _
DAQmx_Val_Rising, DAQmx_Val_AcquisitionType_FiniteSamps, VCycs)
DAQmxErrChk DAQmxSetCICountEdgesTerm(VoutCycHandle, "Dev1/Ctr1", "/Dev1/PFI3")
DAQmxErrChk DAQmxStartTask(VoutCycHandle)
Label17.Caption = "Voltage cycles: "
End If
Timer1.Interval = AcqTime.Value * 1000
Timer1.Enabled = True
Label13.Caption = "Total photons: "
Else
NumBins = AcqTime.Value * 1000 / AcqBinSize.Value
' The functions DAQmxSetCICountEdgesTerm and DAQmxSetCIFreqTerm
' do not appear anywhere in the documentation. But they can be found in
' C:\Program Files\National Instruments\NI-DAQ\DAQmx ANSI C Dev\include\NIDAQmx.h
' and need to be called to set the proper connections
DAQmxErrChk DAQmxCreateCIFreqChan(PhotBinHandle, "Dev1/Ctr1", "", 1, _
DAQmx_Val_CounterFrequencyMethod_HighFreq2Ctr, AcqBinSize.Value / 1000, 4, "")
NumBins + 1)
Do
If chkSaveV Then
Else
VInFlag = False
End If
If chkSaveAOV Then
Else
AOVInFlag = False
End If
DoEvents
cmdStop_Click
End If
End Sub
Private Sub Timer1_Timer()
Timer1.Enabled = False
cmdStop_Click
End Sub
Private Sub cmdStop_Click()
chkSaveV.Enabled = True
chkSaveAOV.Enabled = True
cmdStop.Enabled = False
If AcqFlag Then
StopAcq
End If
cmdFocus.Enabled = True
If VOutFlag Then
cmdVStop.Enabled = True
Else
cmdVStart.Enabled = True
End If
End Sub
Private Sub StopFocus()
FocusFlag = False
DAQmxErrChk DAQmxStopTask(PhotBinHandle)
DAQmxErrChk DAQmxClearTask(PhotBinHandle)
End Sub
10-03-2008 12:18 PM
Private Sub StopAcq()
AcqFlag = False
Label6.Caption = ""
DAQmxReadCounterF64 PhotCtrHandle, BuffSize, 0#, CtrDat(1), BuffSize, _
DAQmxErrChk DAQmxStopTask(PhotCtrHandle)
DAQmxErrChk DAQmxClearTask(PhotCtrHandle)
Label13.Caption = "Total Photons: " & sampsPerChanRead
If VOutFlag Then
ReDim VoutTimes(1 To VCycs) As Double
DAQmxReadCounterF64 VoutCycHandle, VCycs, 0#, VoutTimes(1), VCycs, VcycsRead, ByVal 0&
DAQmxErrChk DAQmxStopTask(VoutCycHandle)
DAQmxErrChk DAQmxClearTask(VoutCycHandle)
Label17.Caption = "Voltage cycles: " & VcycsRead
End If
Else
ReDim BinDat(1 To NumBins + 1) As Double
DAQmxReadCounterF64 PhotBinHandle, NumBins + 1, 0#, BinDat(1), NumBins + 1, _
If BinFlag Then
BinFlag = False
End If
Label13.Caption = "Bins Collected: " & sampsPerChanRead
If chkSaveAOV Then
If AOVInFlag Then
AOVInFlag = False
End If
End If
If chkSaveV Then
ReDim VInDat(1 To 2 * (SampsPerSec * AcqTime) + 1) As Double
DAQmxReadAnalogF64 VInHandle, (SampsPerSec * AcqTime), 0#, DAQmx_Val_GroupByScanNumber, _
If VInFlag Then
DAQmxErrChk DAQmxStopTask(VInHandle)
VInFlag = False
End If
DAQmxErrChk DAQmxClearTask(VInHandle)
End If
End If
frmSave.Show
End Sub
Public Sub cmdSave()
Label7.Caption = "saving"
Open Path.Text & "\" & Filename.Text & "_tt_header.txt" For Output As #1
Else
Open Path.Text & "\" & Filename.Text & "_bin_header.txt" For Output As #1
End If
Print #1, Date & ", " & Format(Time, "hh:mm:ss AMPM")
Print #1, "Yan *****"
Print #1, "******** University"
Print #1, "Time-tagging of photons with 100 ns resolution."
Print #1, "40 kHz AOM rotation --> 250 counts/rotation, phase-locked to time-tagging clock."
Print #1, sampsPerChanRead & " total photons detected."
Print #1, "Duration of experiment: " & (CtrDat(sampsPerChanRead) - CtrDat(1)) / 10000000# & " s."
Print #1, "Intervals between successive photons given in units of 100 ns."
Else
Print #1, "Binning of photons in bins of " & AcqBinSize.Value & " ms."
Print #1, sampsPerChanRead & " bins acquired over " & AcqTime.Value & " s."
End If
Print #1,
Print #1, "Carrier: "
If OptSine Then
Print #1, "Sine Wave."
ElseIf OptSquare Then
Print #1, "Square Wave."
Else
Print #1, "Triangle Wave."
End If
Print #1, Freq.Value & " Hz"
Print #1, Phase.Value & " Degrees"
Print #1, "Vx: " & XAmp.Value & " V"
Print #1, "Vy: " & YAmp.Value & " V"
Print #1, "AM Modulation: "
If OptAMSine Then
ElseIf OptAMSquare Then
Else
End If
Print #1, "Frequency: " & Freq.Value / AMPer.Value & " Hz"
Print #1, "% modulation: " & AMAmp
Print #1, "Offset:"
Print #1, "Vx: " & XOff.Value & " V"
Print #1, "Vx Modulation Amplitude:" & XoffAmp.Value & "V"
Print #1, "Vy: " & YOff.Value & " V"
Print #1, "Vy Modulation Amplitude:" & YoffAmp.Value & "V"
Print #1, "Offset voltage Modulation Frequency:" & Freq.Value / XoffPer.Value & "Hz"
Print #1, "Lockin: "
Print #1, "Amplitude: " & LockinAmp.Value & " V"
Print #1, "Delay: " & LockinPhase.Value & " data points"
If chkSaveV Then
Print #1,
Print #1, "Voltage recorded at 40,000 Hz"
Print #1, "Voltage samples read: " & VsampsPerChanRead
End If
If chkSaveAOV Then
Print #1,
Print #1, "AOM driving voltage recorded at 40,000 Hz"
Print #1, "AOM driving voltage read: " & VsampsPerChanRead
End If
Close #1
Open Path.Text & "\" & Filename.Text & "_tt.txt" For Output As #2
For i = 2 To sampsPerChanRead
Write #2, CtrDat(i) - CtrDat(i - 1)
Next i
Else
Open Path.Text & "\" & Filename.Text & "_bin.txt" For Output As #2
Write #2, BinDat(i) * AcqBinSize.Value / 1000
Next i
End If
Close #2
If chkSaveV Then
Open Path.Text & "\" & Filename.Text & "_Vin.txt" For Output As #4
For i = 1 To VsampsPerChanRead
Print #4, Format(VInDat((2 * i) - 1), "##.000") & ", " & Format(VInDat(2 * i), "##.000")
Next i
Close #4
End If
If chkSaveAOV Then
Open Path.Text & "\" & Filename.Text & "_AOVin.txt" For Output As #5
Print #5, Format(AOVInDat(i), "##.000")
Next i
Close #5
End If
Label7.Caption = ""
End Sub
10-03-2008 12:18 PM
Private Sub cntMax_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
If cntMax.Value > cntMin.Value Then
CWGraph1.Axes(2).Maximum = cntMax.Value
Else
cntMin.Value = cntMax.Value - 1
CWGraph1.Axes(2).SetMinMax cntMin.Value, cntMax.Value
End If
End Sub
Private Sub cntmin_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
If cntMin.Value < cntMax.Value Then
CWGraph1.Axes(2).Minimum = cntMin.Value
Else
cntMax.Value = cntMin.Value + 1
End If
End Sub
Private Sub cmdvstart_Click()
Dim errorCode As Long
Dim errorString As String
Dim numchannels As Long
On Error GoTo ErrorHandler
'On Error Resume Next
' Create the DAQmx task.
' Add an analog output channel to the task
DAQmxErrChk DAQmxCreateAOVoltageChan(VOutHandle, "Dev1/ao0:3", "", _
-10#, 10#, DAQmx_Val_VoltageUnits2_Volts, "")
'set to run only using onboard fifo (Essential for freqs > 28 kHz)
DAQmxErrChk DAQmxSetAOUseOnlyOnBrdMem(VOutHandle, "Dev1/ao0:3", True)
UpdateWaveform
Exit Sub
ErrorHandler:
If VOutFlag Then
DAQmxStopTask VOutHandle
DAQmxClearTask VOutHandle
VOutFlag = False
End If
MsgBox "Error: " & Err.Number & " " & Err.Description, , "Error"
End Sub
Private Sub SetSampsPerCycle()
If Freq.Value > 8000 Then
SampsPerCarCyc = Fix(0.8 * DARate / Freq.Value)
Else
SampsPerCarCyc = 160
End If
SampsPerModCyc = SampsPerCarCyc * AMPer
SampsPerXoffCyc = SampsPerCarCyc * XoffPer
LockinPhase.Maximum = SampsPerModCyc
End Sub
Private Sub cmdVStop_Click()
StopVOut
End Sub
Private Sub UpdateWaveform()
SetSampsPerCycle
ReDim VOut(0 To 3, 0 To SampsPerXoffCyc - 1)
ReDim VCarrier(0 To 2, 0 To SampsPerCarCyc - 1)
ReDim VMod(0 To SampsPerModCyc - 1)
ReDim VXoff(0 To SampsPerXoffCyc - 1)
ReDim VYoff(0 To SampsPerXoffCyc - 1)
ReDim Vtemp(0 To SampsPerModCyc - 1)
SampFreq = SampsPerCarCyc * Freq.Value
' Gather data points for a sine, square or triangle wave base.
If OptSine Then
MakeSine
MakeSquare
ElseIf OptTri Then
MakeTri
End If
' Make a 90 degree phase-shifted copy of the carrier
For i = 0 To (SampsPerCarCyc - 1)
j = CInt((i + SampsPerCarCyc / 4) Mod SampsPerCarCyc)
VCarrier(1, i) = VCarrier(0, j)
Next i
' Make the modulation signal
If OptAMSine Then
MakeAMSine
MakeAMSquare
ElseIf OptAMTri Then
MakeAMTri
End If
' Make the X offset modulation signal
MakeXoffSquare
MakeYoffSquare
'put the signals together, with appropriate phase shifts
For i = 0 To SampsPerXoffCyc - 1
'Here are the AOM drive signals
j = CInt(i + Phase * SampsPerCarCyc / 360)
VOut(0, i) = XAmp * VCarrier(0, i Mod SampsPerCarCyc) * VMod(i Mod SampsPerModCyc) + VXoff(i)
VOut(1, i) = YAmp * VCarrier(2, i Mod SampsPerCarCyc) * VMod(j Mod SampsPerModCyc) + VYoff(j Mod SampsPerXoffCyc)
'Here are the lockin signals
k = i + SampsPerModCyc - LockinPhase
VOut(2, i) = LockinAmp * VCarrier(0, k Mod SampsPerCarCyc) * VMod(k Mod SampsPerModCyc)
VOut(3, i) = LockinAmp * VCarrier(1, k Mod SampsPerCarCyc) * VMod(k Mod SampsPerModCyc)
Next
If VOutFlag Then DAQmxErrChk DAQmxStopTask(VOutHandle)
' Configure task for continuous waveform generation.
DAQmxErrChk DAQmxCfgSampClkTiming(VOutHandle, "", SampFreq, _
DAQmx_Val_Falling, DAQmx_Val_AcquisitionType_ContSamps, CLng(SampsPerXoffCyc))
' Write to the desired channel(s).
DAQmxErrChk DAQmxWriteAnalogF64(VOutHandle, SampsPerXoffCyc, True, 10#, _
DAQmx_Val_GroupByScanNumber, VOut(0, 0), sampsPerChanWritten, ByVal 0&)
Label5.Caption = "Samples/channel: " & sampsPerChanWritten
'DAQmxErrChk DAQmxStartTask(VOutHandle)
VOutFlag = True
End Sub
Private Sub StopVOut()
' Stop the DAQmx task.
VOutFlag = False
'write zeros to the three output channels
DAQmxErrChk DAQmxCreateAOVoltageChan(VOutHandle, "Dev1/ao2", "", -10, 10, DAQmx_Val_VoltageUnits2_Volts, "")
DAQmxErrChk DAQmxWriteAnalogScalarF64(VOutHandle, True, 10#, 0#, ByVal 0&)
DAQmxErrChk DAQmxCreateAOVoltageChan(VOutHandle, "Dev1/ao3", "", -10, 10, DAQmx_Val_VoltageUnits2_Volts, "")
End Sub
' Initialize the data array for sine wave creation
Private Sub MakeSine()
Const Pi As Double = 3.1415926535
VCarrier(0, i) = Sin((i * 2 * Pi) / SampsPerCarCyc)
VCarrier(2, i) = Sin(((i + SampsPerCarCyc / 4 + Phase * SampsPerCarCyc / 360) * 2 * Pi) / SampsPerCarCyc)
Next i
End Sub
' Initialize the data array for square wave creation
Private Sub MakeSquare()
VCarrier(0, i) = Sgn(0.01 + Sin((i * 2 * 3.14) / SampsPerCarCyc))
VCarrier(2, i) = Sgn(0.01 + Sin(((i + Phase * SampsPerCarCyc / 360) * 2 * Pi) / SampsPerCarCyc))
Next i
End Sub
10-03-2008 12:18 PM
' Initialize the data array for triangle wave creation
Private Sub MakeTri()
If i < SampsPerCarCyc / 2 Then
VCarrier(0, i) = (4 * i / SampsPerCarCyc) - 1
Else
VCarrier(0, i) = 3 - 4 * i / SampsPerCarCyc
End If
Next i
If (i + Phase * SampsPerCarCyc / 360) < SampsPerCarCyc / 2 Then
VCarrier(2, i) = (4 * (i + Phase * SampsPerCarCyc / 360) / SampsPerCarCyc) - 1
Else
VCarrier(2, i) = 3 - 4 * (i + Phase * SampsPerCarCyc / 360) / SampsPerCarCyc
End If
Next i
End Sub
Private Sub MakeAMSine()
For i = 0 To (SampsPerModCyc - 1)
VMod(i) = 1 + (AMAmp / 100) * Sin((i * 2 * Pi) / SampsPerModCyc)
Next i
End Sub
Private Sub MakeAMSquare()
VMod(i) = 1 + (AMAmp / 100) * Sgn(0.01 + Sin((i * 2 * Pi) / SampsPerModCyc))
Next i
End Sub
Private Sub MakeAMTri()
If i < SampsPerModCyc / 2 Then
VMod(i) = 1 + (AMAmp / 100) * ((4 * i / SampsPerModCyc) - 1)
Else
VMod(i) = 1 + (AMAmp / 100) * (3 - 4 * i / SampsPerModCyc)
End If
Next i
End Sub
Private Sub MakeXoffSquare()
For i = 0 To (SampsPerXoffCyc - 1)
If i < SampsPerXoffCyc / 2 Then
VXoff(i) = XOff.Value + XoffAmp.Value
Else
VXoff(i) = XOff.Value - XoffAmp.Value
End If
Next i
End Sub
Private Sub MakeYoffSquare()
VYoff(i) = YOff.Value + YoffAmp.Value
Else
VYoff(i) = YOff.Value - YoffAmp.Value
End If
Next i
End Sub
Private Sub Form_Unload(Cancel As Integer)
' Quit the program.
If VOutFlag Then
StopVOut
End If
End
End Sub
Private Sub OptSine_Click()
OptSquare.Value = False
OptTri.Value = False
If VOutFlag Then UpdateWaveform
End Sub
Private Sub OptSquare_Click()
OptSine.Value = False
End Sub
Private Sub OptTri_Click()
End Sub
Private Sub OptAMSine_Click()
OptAMSquare.Value = False
OptAMTri.Value = False
End Sub
Private Sub OptAMSquare_Click()
OptAMSine.Value = False
End Sub
Private Sub OptAMTri_Click()
End Sub
Private Sub Freq_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub Phase_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub XAmp_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub YAmp_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub AMPer_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub AMAmp_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub XOff_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub XoffAmp_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub XoffPer_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub YOff_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub YOffAmp_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub LockinAmp_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub LockinPhase_ValueChanged(Value As Variant, PreviousValue As Variant, ByVal OutOfRange As Boolean)
End Sub
Private Sub optBinned_Click()
optTimeTagged.Value = 0
optBinned.Value = 1
End Sub
Private Sub optTimeTagged_Click()
optBinned.Value = 0
optTimeTagged.Value = 1
End Sub
10-06-2008 09:53 PM
Hi Yan,
I have tried striping down your code to simply two analog input tasks with the chksave and chksaveAOV, but did not observe the behavior you are describing. Could you perhaps try doing the same and seeing if this problem persists. If you do not wish to troubleshoot the code, maybe we can make some modifications in the hopes of working around this problem. My recommendation is that since you will only be running one of the two input tasks at any given time, you can all task related functions such as creation, configuration, operation and cleanup in one large if statement rather than having multiple if statement checks for each stage.
There must be something that we are overlooking, but I believe that this suggestion may help work around the problem, not mentioning the fact the code will also look a lot cleaner.
