10-30-2013 12:56 PM
When I perform the below function GetData, Call ReadStatusByte(0, GPIBAddress,
spr%) returns many responses. I would like to understand what these number
mean. Can you expand on this?
The definitions of the Hierarchy is found below. The final call,
ReadStatusByte32, is within the VBIB32 Module.
I get values such as 128, 4.....and am looking for a list of what these all mean.
Public Function GetData(GPIBAddress, sendstring) As String
ErrorLocation = "GetData"
On Error GoTo errorhandler
Dim ReadThis As String, spr As Integer, ReadTemp As String
Dim ReRead As Integer
Dim ReReadCnt As Integer
'Dim ErrorLocation As String
ReReadCnt = 0
ReadThis = ""
ReadThis = Space$(200) 'space$(180)
spr = 0
resend:
Call Send(0, GPIBAddress, sendstring, NLend)
Call ReadStatusByte(0, GPIBAddress, spr%) '144= ok, 208=ok,
128=trouble(empty), 148= ? , 132 = ? 20 = ok 16 = ok 4 = ?
Do While (spr% <> 208 And spr% <> 144 And spr% <> 148 And spr% <> 16 And
spr% <> 20 And spr% <> 132 And ReReadCnt < 20) ' 0 ' give readstatusbyte a
chance to switch
If ReReadCnt > 10 Then ' if readstatusbyte does not correct clear the
device and resend to retrieve data after 10 tries.
Call DevClear(0, GPIBAddress)
Call ibclr(GPIBAddress)
Call ErrorLog("Error Tracker: Read Status Byte returned a " & spr%
& ". DevClr/ibclr handled the error. " & FormatDateTime(Now, vbLongDate) & " ,
" & FormatDateTime(Now, vbLongTime))
ReReadCnt = ReReadCnt + 1
GoTo resend
End If
Loop
Call Receive(0, GPIBAddress, ReadThis, STOPend)
GetData = Trim(ReadThis)
Exit Function
errorhandler:
Call ErrorLog(Err.Number & " , " & Err.Description & " , " & ErrorLocation
& " , " & FormatDateTime(Now, vbLongDate) & " , " & FormatDateTime(Now,
vbLongTime))
Select Case Err.Number
Case 13
msgbox (ErrorLocation)
Case Else
msgbox (Err.Number & ", " & Err.Description & " , " & ErrorLocation)
End Select
Resume Next
End Function
Sub ReadStatusByte(ByVal ud As Integer, ByVal addr As Integer, result As
Integer)
Dim tmpresult As Long
' Check to see if GPIB Global variables are registered
If (GPIBglobalsRegistered = 0) Then
Call RegisterGPIBGlobals
End If
' Call the 32-bit DLL.
Call ReadStatusByte32(ud, addr, tmpresult)
result = ConvertLongToInt(tmpresult)
Call copy_ibvars
End Sub
Declare Sub ReadStatusByte32 Lib "Gpib-32.dll" Alias "ReadStatusByte" (ByVal ud
As Long, ByVal addr As Long, result As Long)
10-31-2013 08:31 AM - edited 10-31-2013 08:32 AM
Hey cmseguin,
This is a question that is that would fit better on the Instrument Control Boards since the method is a member of the GPIB communication library and not the Measurement Studio libraries. That being said it is difficult to find documentation for VB6, since much of the documentation online is newer. One of the better documents I found was this from the 2013 LabVIEW Help:
http://zone.ni.com/reference/en-XX/help/371361K-01/lvinstio/gpib_read/
The Status section of the article has a table with the different values and what they correspond with.
This article, called Using Service Requests in your GPIB application gives a more general overview of the 488.2 protocol that might shed more light on the standard:
http://www.ni.com/white-paper/4629/en/
If you have more questions feel free to post to the Instrument Driver board.
Best,
-KP
11-21-2013 07:31 AM
Hi Kurt,
I posted this on the Instrument Control Forum.
As you stated your advice was more related to NI Labview. My return values are different then those described in the readings.
Chris
