Measurement Studio for VB6
Starting IMAQ Operation
I am currently developing an application in Visual Basic 6.
The detail that I have is that even programming examples of the IMAQ TO VISUAL BASIC manual on the screen I get the following error.
30839 ' Error'
IMAQ starting Operation
No Interface Found
Someone could tell me because you get this error, work with a USB web camera, connected directly to the computer, the error comes out in the next instruction CWIMAQ1.Start.
Feene Afkan Zeero
(7,691 Views)
Hello Feene,
The error code that you are getting is a Microsoft error code, I am trying to get the meaning of that code. However, I am wondering if you can see your camera in MAX, because if you cannot that is the reason of why Visual cannot find the camera either.
In order tu use the USB cameras with IMAQdx, the camera needs to be compatible with the driver, here is a KB about troubleshooting your USB camera:
http://digital.ni.com/public.nsf/allkb/C1BC2D93ADC392BB8625768C0060AFE7
Take a look at to see if the problem is with the HW or with the SW.
Luis Elias
NI VeriStand and HIL Product Manager
(7,681 Views)
Me encargare de realizar Pruebas con MAX.
Tambien me he dispuesto a descargar los modulos VAS y VDM, para que en su defecto desarrolle la palicacion en LabView.
Os mantendre informado de los resusltados.
Gracias
Feene Afkan Zeero
(7,678 Views)
Perfecto,
Una cosa importante, para que una cámara USB esta debe de ser compatible con Direct Show: http://msdn.microsoft.com/en-us/library/windows/desktop/dd375454(v=vs.85).aspx
Si no, no podrás ver esta en MAX:
Saludos,quedo al tanto de la situación
Luis Elias
(7,676 Views)
Bien mientras reviso esta informacion, creo que olvide mencionarte:
1. La version de LabVIEW con la que trabajo es la 8.6
2. Las versiones de los modulos VAS y VDM instaladas en mi PC son la 8.5 y la 8.6 respectivamente.
3. El la Paleta de LabVIEW "Vision and Motion" solo se carga un Componente.
4. La web cam que utilizo no requirio driver para la instalacion, para capturar fotos la abro desde  MI PC, como un dispositivo de lamacenamiento comun.
5. El sistema Operativo con el que trabajo es el Windows XP Professional Service Pack 3.
espero estos datos ayuden a resolver la incognita del error gnerado en Visual Basic 6.0
como siempre agradecido por tu tiempo y tu atencion quedo de ti.
Nota:
Hice una consulta en otro foro sobre lo de la paleta "Motion and Vision", la parsona que respondio sugirio descargara los modulos (Lo indico en versiones de los drivers IEEE y IMAQdx) que segun la tabla de compativilidades van del 8.5 al 2010, y por el momento me encuentro descargandolos, a mas tardar espero el proximo martes tenerlos instalados, a ver que sucede.
Feene Afkan Zeero
(7,673 Views)
ya instale los modulos y logre lo que se queria, la camara en efecto es compatible con Direc Show, la paleta Motion and Vision esta ya con mas componetes pero el error de IMAQ con Visul Basic Persiste
Feene Afkan Zeero
(7,660 Views)
