Measurement Studio for VB6
Simultaneous Digital Write and Read w. Interval Measurement
Hi all,
For the past couple days, I've been wracking my brain trying to get a program to work.
I'm trying to generate a 4-bit digital output while simulatanously counting the rising edges on its LSB up to an arbitary number set by the program's operator, at which point, the program would make a measurement.
I'm noticing, though, that, over a certain rising edge count number (~950 or so), the program crashes. The problem persists even when I remove the function that reads the LSB, although, in that case, the crashes occur at a much higher number. What might cause this? Is there any way I can work around this problem?
Below is my code:
arraySizeInBytes2 = 8
bufferSize = 255
ReDim readArray(arraySizeInBytes2)
publicLifetime = 100 ' use this to control the length of time the task takes
numSamplesToWrite = 10 * publicLifetime * numSample * 5
numSamplesInArray = 5 * 10 * numSample
'code that defines the digital and analog output signals
j = 0
  k = -1
    Do While j < numSamplesInArray
        If j Mod SampPerCycle = 0 Then k = k + 1 Else k = k
        For m = 0 To 3
        If ((k) And (2 ^ m)) = (2 ^ m) Then writeArray(m, j) = 1 Else: writeArray(m, j) = 0
        Next m
        j = j + 1
        Loop
    publicStatus = DAQmxCreateTask("", taskHandleDigitalOut)
    publicStatus = DAQmxCreateTask("", taskHandleAnalog)
    publicStatus = DAQmxCreateTask("", taskHandleDigitalIn)
    taskIsRunning = True
     publicStatus = DAQmxCreateDOChan(taskHandleDigitalOut, "Dev2/port0/line0:3", "", DAQmx_Val_ChanForAllLines)
     publicStatus = DAQmxCfgSampClkTiming(taskHandleDigitalOut, "Ctr0InternalOutput", 1000000#, DAQmx_Val_Falling, DAQmx_Val_AcquisitionType_FiniteSamps, numSamplesToWrite)
     publicStatus = DAQmxCreateAOVoltageChan(taskHandleAnalog, "dev2/ao0", "", -10, 10, DAQmx_Val_VoltageUnits2_Volts, "")
     publicStatus = DAQmxCfgSampClkTiming(taskHandleAnalog, "Ctr0InternalOutput", 1000000#, DAQmx_Val_Falling, DAQmx_Val_AcquisitionType_FiniteSamps, numSamplesToWrite)
     publicStatus = DAQmxCreateDIChan(taskHandleDigitalIn, "dev2/port0/line7", "", DAQmx_Val_ChanPerLine)
     publicStatus = DAQmxCfgChangeDetectionTiming(taskHandleDigitalIn, "dev2/port0/line7", "", DAQmx_Val_AcquisitionType_ContSamps, 8)
     publicStatus = DAQmxWriteBinaryI16(taskHandleAnalog, DACwaveFormSize, False, -1, DAQmx_Val_GroupByScanNumber, buffer(0), sampsPerChanWritten, ByVal 0&)
     publicStatus = DAQmxWriteDigitalLines(taskHandleDigitalOut, numSamplesInArray, False, -1, DAQmx_Val_GroupByScanNumber, writeArray(0, 0), sampsPerChanWritten, ByVal 0&)
     publicStatus = DAQmxStartTask(taskHandleDigitalIn)
     publicStatus = DAQmxStartTask(taskHandleAnalog)
     publicStatus = DAQmxStartTask(taskHandleDigitalOut)
     publicStatus = DAQmxStartTask(publicCounterHandle)
r = 0
Do While r < (publicLifetime * numSample)
publicStatus = DAQmxReadDigitalLines(taskHandle, 1, 5, DAQmx_Val_GroupByScanNumber, readArray(0), arraySizeInBytes2, SampsPerChanRead, numBytesPerSamp, ByVal 0&)
If publicStatus = 0 Then r = r + 1
If r Mod publicMeasurementInterval= 0 Then 'Measurement Code here
Loop
publicStatus = DAQmxStopTask(taskHandleDigitalIn)
 publicStatus = DAQmxWaitUntilTaskDone(taskHandleDigitalOut, -1)
 publicStatus = DAQmxClearTask(taskHandleDigitalOut)
 publicStatus = DAQmxStopTask(taskHandleAnalog)
 publicStatus = DAQmxClearTask(taskHandleAnalog)
 publicStatus = DAQmxStopTask(publicCounterHandle)
 publicStatus = DAQmxClearTask(taskHandleDigitalIn)
 taskIsRunning = False
Thank you.
Message 1 of 9
(8,398 Views)
FWIW, I'm using an PCI-6259 connected to an SCB-68.
Message 2 of 9
(8,379 Views)
Do you receive any type of error message or code when this occurs?
Message 3 of 9
(8,373 Views)
Just an overflow error.
For what it's worth, I've been able to get the maximum number of cycles up to 2047 by changing the line
to
publicStatus = DAQmxCfgChangeDetectionTiming(taskHandleDigitalIn, "dev2/port0/line7", "", DAQmx_Val_AcquisitionType_FiniteSamps, publicLifetime * numSample)
What do you think that might mean?
Message 4 of 9
(8,361 Views)
Specifically what error are you getting, and does it give you a code?
Message 5 of 9
(8,351 Views)
You may need to read more samples from your device. It sounds like you could possibly have a buffer overflow.
Message 6 of 9
(8,348 Views)
I get the 6 error. I'm currently trying to expand the read array size. I'll let you know how that goes.
Thank you for your help, by the way.
Message 7 of 9
(8,340 Views)
Still having difficulty. I tried increasing the buffer size (which I'm presuming is for the DAQmxReadDigitalLines command) but to no avail. For what it's worth, I used the error line feature of VB and found that the program crashes on the line
"If publicStatus = 0 Then r = r + 1"
I can get the program to write however many samples I want. The problem is entirely within that read loop.
Message 8 of 9
(8,331 Views)
Accepted by topic author Armando83
You were right: it was a buffer overflow. I was using integer numbers when I should have been using doubles.
Thank you for your help.
Message 9 of 9
(8,320 Views)
