05-06-2004 06:13 PM
05-07-2004 10:59 AM
05-10-2007 09:40 PM
hi,
i dono whether this is the correct forum for this question..if its not,could someone please direct me to the correct one?
here's my problem:
im trying to not use the CWIMAQViewer at all in my application(im using VB.NET).is it possible for me to directly save the image from Grab into a variable?i have gone thru the examples provided,but i dont understand the connection between the Viewer and the variable that i declare for the image acquired using Grab..i dont see any code that actually saves the image from Grab into the variable.even if i omit the IMAQViewer.Attach() code,the program is working fine.so,is there a way to do it?the reason i dont want to use the Viewer is because i dont need the image to be displayed or anything.i just need to do some color matching and return the color of a region in the image.
thank you..
05-14-2007 11:20 AM
05-14-2007 07:20 PM
05-14-2007 10:13 PM
at:
CWIMAQVision1.LearnColor(myImage, ColInfo, ViewRect)
wer myImage is the image from grab(), ColInfo is the color info, and ViewRect is the region.when i debug,i can see that there is no image height and width.so i suspect that the image is not passed to the LearnColor correctly.but myImage is a global variable,so i dont understand y the function cant access it..i've even tried pasting all the grab codes before LearnColor,but still getting the same error..
very grateful if someone can help..need to finish this by today..
thank u so much!!
05-16-2007 10:10 PM
05-25-2007 10:29 AM
05-27-2007 09:30 PM
hi luke,
im sorry,but i dont understand wat u mean by " Where is your project at?"..did u mean the direactory where i save my project?
i save it in: P:\MyDocuments\Visual Studio Projects\vision4..and sorry if this is not wat u wanted..
anyway,wat im trying to do is use this application as a dll and call it from a console based application.the delay still exists,coz when i debug,i can see that the image doesnt exist in the variable just before i use it for my LearnColor.
since placing the image acqusition codes in the form load event solved the problem in my earlier app,i placed them in the constructor for the library.and guess wat..it worked!!
i also used a timer that fires every 250ms.in the timer fired event,i placed the grabCW2 codes..and i also put a 1 second delay just before the LearnColor function.
but if there is a way to place all codes in one main function,i would be very happy..coz,as i said earlier,i want all actions to be initiated by the user..if only i could solve the delay in saving the image,then im done...
thank you so much for your help..
05-27-2007 10:06 PM
oops..its supposed to be Grab2CW
