Grant:
The ComponentWorks CWAI control--and most of the data acquisition controls--provide the ability to bind attributes to channels. For instance, for every channel, I can specify a lower limit and an upper limit for my acquisition. These limits are used to determine the gain applied to the signal. Gains help you more effectively use the resolution of your data acquisition device to measure a signal that may only span a subset of the voltages your board is capable of measuring. You can setup these values when you add your channels to the ComponentWorks controls, either through the property pages or programmatically with
CWAI1.Channels.Add ChannelString [, UpperLimit] [, LowerLimit] [, InputMode] [, Coupling]
Please see the ComponentWorks documentation for more i
nformation on using these parameters.
Good Luck!
Chris Wood
Applications Engineer
