05-11-2013 05:50 PM
hello,
I need to control the on and off of a trasistor, for that i need to give a on pulse with 1ms and off pulse of 360ms using ni usb 6009. is there any example vi for that.
07-24-2013 06:04 AM
I have same query and also what to know about this...
08-01-2013 04:57 AM
Make sure you have installed the Measurement studio support for VB 6.0 then you will be able to find examples in the folder below on win7 and 8.
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples
Narrow down to Analog Output and choose update voltage example for measurement studio.
You also have the possibility to use DAQ assistant if you have measurement studio installed. This function is a configuration type programming. After going through the configuration Wizard code is automatically scripted for you so that you can output the voltage you need. Read more about DAQ assistant in the blow link.
http://www.ni.com/white-paper/4652/en/
