Measurement Studio for VB6
How to convert a VB code(Comm1.Output=Chr$(7)+"R"+Chr$(13)) to labview code
I have a question about serial communication.
The code was written by VB, and I want to transform them to labview.
One of the code in VB is: Comm1.Output=Chr$(7)+"R"+Chr$(13), it means 'bell+R+carriage return' were sent to com1 port.
But I don't know how to write this code in labview.
Could anyone help me?
Great thanks
(6,655 Views)
Hi cctt126,
I would recommend you re-post this question in either the LabVIEW forum or the GPIB/Serial forum. Those forums are much more active and more likely to get you a response. Also, since VB is a less commonly used language and there’s probably not a direct translation into LabVIEW, you might provide more of a description of what you are trying to accomplish with your code. Thanks!
That said, LabVIEW has several built-in examples for serial communication that should help you get started. You can find them by navigating to Help>>Find Examples in LabVIEW, then Hardware Input and Output>>GPIB. If you don’t have the NI-VISA driver installed (or if you installed LabVIEW after installing the driver) the examples may not show up.
Kelsey Johnson
Applications Engineer
(6,644 Views)
Thanks.
Type cast could be used to realize the function of Chr$(7) and Chr$(13).
Just be careful about the data precision of Type cast input.
(6,559 Views)
