09-01-2011 05:52 PM
Am using a measurement studio graph (strip chart)(cwui.ocx) in a vb.net project. I want to be able to "turn off" a trace on a multi trace graph. If I set a particular trace color to the graph background color (white), it hides other traces at points of intersect. If I set the trace to be off screen, you see the vertical portions of that trace as it goes off screen. Is there another way to "turn off" a trace and not have it be visible.
Bart
09-03-2011 03:26 PM
Hi bartinoregon,
What version of mesurement studio are you using? What version of VB are you using? Can you upload a screen shot of what you have so that I could see what you arte working with?
Perry S.
09-03-2011 04:49 PM
Perry,
I found a solution...but it was too obvious. I did not see the .trace.visible property originally. Now all OK.
BTW was using verion 6 of measurement studio with VB.net 2008.
Bart J
09-06-2011 11:02 AM
Hi bartinoregon,
Thanks for letting me know. I am happy that you found a solution.
Perry S.
