Measurement Studio for VB6
How do I set 76800 baud rate on a PCI485 card under NT
(3,708 Views)
Setting the serial port to the 76800 baud rate for that card can be done the same as any other baud rate. Simply set CWSerial.BaudRate to 76800 before doing a CWSerial.Configure.
However, if a built-in serial port is set to 76800 baud, an error is likely to occur. Use NI-Ports to confirm that certain serial port is an NI-port.
(3,708 Views)
That would be fine if the 76800 was an option I could choose. Under NT my drivers do not let me select this baud rate. I've heard that the Win95 drivers do so I was looking for the API interface parameters to set so I can can patch my driver.
(3,708 Views)
