Rob,
Linking to MFC as a static library is not supported in the current version
of MeasurementStudio.
The NI MeasurementStudio AppWizard is built on top of the MFC AppWizard.
The MFC AppWizard is not fully customizable, so we were not able to disable
this choice.
In the next version of MeasurementStudio, we are considering adding support
for linking to MFC statically. Is this capability important to you?
David Rohacek
"Rob Bryers" wrote:
>>I have compiled and run the "Plot Styles" example project using "Use MFC
in>a Shared DLL". However, after changing the project settings to "Use MFC
in>a Static Library" I get numerous linking errors. This option is avilable>in
the NI Appwizard so I would expect there to be
no problems. Can anyone>enlighten
me?
