11-26-2012 12:02 AM
Hi all,
I have the project using camera and check the parts on electronic board, If part is missing, we will draw the rectangle for this position.
I think 2 ways for this project :
Idea 1: Take 1 electronic board picture from camera and compare with same picture. ( using golden template.)
=> However, we can not draw the rectangle for part by part on elect. board.
=> Can not make the library for part kind on board.
Idea 2 : Will using the CWIMAQvision colorlearn by adding the rectangle and colorlearn for rectangle area.
After that we save data of sample to .TXT file.
When we load new picture for checking, we will compare the rectangle area color with our data in attached file.
If it's different => It's missing part or ..
Idea 3 ......
Everybody pls help me to advice the best solution with your experience.
If posible, pls give me your example for this.
Thanks so much for your reading.
Tonnybui
11-27-2012 09:08 AM
Hello Tonnbui,
These whitepaper might be a good place to start:
Image Analysis and Processing
http://www.ni.com/white-paper/3470/en
Using Edge Detection in Machine Vision Gauging Applications: How to Inspect for missing components
http://www.ni.com/white-paper/4536/en#toc6
As long as the images you are looking at are of the same size and orientation, establishing a known "good" line map or rake is probably the least processing-intensive and most robust way to check PCBs with a known layout. Figuring out which part is missing would only require knowing which parts are in which locations on the board.
As for template or pattern matching, these examples might also be worth looking at:
Pattern Matching Example
http://zone.ni.com/devzone/cda/epd/p/id/5594
Color Pattern Matching Example
http://zone.ni.com/devzone/cda/epd/p/id/5548
Hope that helps!
11-27-2012 09:39 AM
Hello 0utlaw,
Thanks for your help.
I already study the CWIMAQvision with Colorclearn and Matchingcolorpattern .
I make the VB6 data same as attached picture.
However, After I clicked the Colorclearn Button, the colorspectrum will display data of rectanguler area.
but I can not use the data of colorspectrum to compare with new image for same rectangle area.
Can you help me for the example VBcode to load 1 rectange (with input name of this rectangle).
We learn color for this rectangle area. After that we will compare with new picture (take from camera) with same rectangle area to detect the missing ( compare color) for part in this rectangle.
Pls support your example code vb.
11-29-2012 12:42 AM
Hello Tonnybui,
The IMAQ shipping examples that are typically located in the National Instruments/Vision/Examples directory are probably the best place to start looking. This may vary slightly based on the release- what version of the Vision Development Module are you using?
Additionally, you may want to take a look at the following:
Tutorial: IMAQ Pattern Matching Examples
http://zone.ni.com/devzone/cda/epd/p/id/1105
and if you're unable to locate the shipping examples, the following KnowledgeBase article describes how to access them:
KnowledgeBase 5S7DFQEN: How Do I Install C, C++, Visual Basic DotNet Examples for Vision Development Module and Vision Builder AI?
http://digital.ni.com/public.nsf/allkb/692DAC7C72E2D4BF8625796000709509?OpenDocument
