NI Home
Cart Cart | Help
You are here:
Reply
Member
Armando83
Accepted Solution
Continuous Digital Output from the PCI-6259
I'm trying to generate a continuous four-bit digital signal (16 samples) from a PCI-6259 that I'm trying to have look like the output of a four-bit counter (0 to 15) from P0.0, P0.1, P0.2, and P0.3. I have no problem creating the task in Measurement and Automation (see attached screenshot).
The issue I'm running into is that I'm not sure what Write function I ought to be using to get my DAQ to go. I've tried using DAQmxWriteDigitalLines and that didn't seem to get me anywhere.
FWIW, here's a snippet of code I've tried to get to work to no avail. My thought is that I could repeat this process for 0 to 15.
index = 0
                    For i = 1 To highPoints
                     writearray1(0) = 0
                     writearray1(1) = 0
                     writearray1(2) = 0
                     writearray1(3) = 0
                     index = index + 1
                     publicStatus = DAQmxWriteDigitalLines(publicDigitalOut0TaskHandle, DACwaveFormSize, True, 5, DAQmx_Val_GroupByScanNumber, writearray(0), publicSampsPerChanWritten, ByVal 0&)
                    Next i
 Am I doing anything wrong? I would greatly appreciate whatever help the community could give.
Member
Josh_B1
Re: Continuous Digital Output from the PCI-6259
Hey Armando,
I noticed that in your code you may referencing the wrong array. You create "writearray1" and then reference writearray. Was this intentional? Also if you go to start>all programs>national instruments>NI-DAQ>Text-Based Code Support you will find the NI-DAQ™mx C Reference Help. You may find this resource useful.
Josh Brown
Applications Engineer
Member
Armando83
I actually corrected that in the (simplified) code, and I wound up getting an overflow error. FWIW, I've got a 20 kHz pulse train driving PF01.
writearray(0) = 1
writearray(1) = 0
writearray(2) = 0
writearray(3) = 0
 What I'll do after the long weekend is check out some of the tutorials to see if they can point me in the right direction.
Member
Armando83
It took me a little while, but I was able to adapt the code from DAQmx Dig Write tutorial for my project.
Thanks!
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
