02-07-2009 02:20 AM
Colleagues,
Does anyone know how to scroll the CWGraph control? Here's the behavior I want to achieve:
1. The graph's X axis spans from 0 to 3000. In the beginning, it's charting a baseline (using ChartY method).
2. Let's say, it charted to 2500, when the user initiates an experiment.
3. Graph immediately scrolls left leaving only the last 500 points of the baseline - this is the part I don't know how to do. The rest can be discarded.
4. Plotting of the experiment continues from 500 onward.
Could anybody give me some suggestions?
- Nick
P.S. I'm using VB6 and Measurement Studio 8.1.11.
Below is the same behavior on a storyboard:
02-11-2009 02:47 PM
Hi Nick,
One way to do this would be to set the axis lower bound to the current x position - 500 and set the upper bound to the lower bound + 3000. If your question is regarding the implementation or if you have other questions,let me know so I can continue helping you!
