NI Home
Cart Cart | Help
You are here:
Reply
Member
zulump
write code in VB.Net to produce analog output for Advantech USB 4716
I'm still confuse on how to write code to produce analog output using advantech usb 4716
i'm using VB 2010.Net as programming language
this is previous code that i used, but when i run the program the textbox display 0. and when i measure the analog output channel using voltmeter 0 V is display.
how can i produce 5V analog output.
I already add the automation.DAQ.dll preference in my project. And i also already, setting the Instant AOCtrl1.
pls show me some guides.
Active Participant nyc
Active Participant
Re: write code in VB.Net to produce analog output for Advantech USB 4716
VB.NET isn't NI
Advantech USB 4716 isn't NI
What are you using that is NI?
Member
zulump
wrong place?
Active Participant
If you are not using any NI product, why would you be posting here???
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
