10-15-2012 02:25 AM
I have a wpf on which I add Point Annotations and Range Annotation programmatically, when the user clicks the the buttons "Take Point Annotation" and "Take Range Annoation". I would like to select an annotation when the user clicks on it an make him able to modify or delete. I used getChildrenAtPoint method of the graph but the collection that this method returns is always empty...
My graph definition is:
<ni:Graph Name="graph" HitTestMode="RenderedInterpolation" PlotAreaMouseLeftButtonUp="graph_PlotAreaMouseLeftButtonUp"> <ni:Graph.Axes> <ni:AxisDouble x:Name="xAxis" Range="0,10" Orientation="Horizontal"></ni:AxisDouble> <ni:AxisDouble x:Name="yAxis" Range="0,20" Orientation="Vertical"></ni:AxisDouble> </ni:Graph.Axes> <ni:Graph.Children> <ni:Cursor Name="simpleCursor"> <ni:Cursor.ValuePresenter> <nic:ValueFormatterGroup> <nic:ValueFormatterGroup.DefaultFormatter> <nic:GeneralValueFormatter x:Name="valueFormatter" Format="0.00"></nic:GeneralValueFormatter> </nic:ValueFormatterGroup.DefaultFormatter> </nic:ValueFormatterGroup> </ni:Cursor.ValuePresenter> </ni:Cursor> <ni:MultiPlotCursor Name="mpCursor" Visibility="Hidden"></ni:MultiPlotCursor> <ni:RangeCursor Name="rangeCursor" HorizontalRange="4,6" VerticalRange="4,6" Visibility="Hidden"></ni:RangeCursor> </ni:Graph.Children> </ni:Graph>
and the the addAnnotation method is:
private void TakeRangeAnnotation_Executed(object sender, ExecutedRoutedEventArgs e) { WindowAnnotation dialog = new WindowAnnotation(); if (dialog.ShowDialog() == true) { NationalInstruments.Controls.RangeAnnotation ann = new NationalInstruments.Controls.RangeAnnotation(); ann.HorizontalRange = rangeCursor.ActualHorizontalRange; ann.VerticalRange = rangeCursor.ActualVerticalRange; ann.Label = dialog.Annotation; ann.HorizontalAxis = xAxis; ann.VerticalAxis = yAxis; graph.Children.Add(ann); } }
I call the getChlidrenAtPoint method on the PlotAreaMouseLeftButtonUp event:
private void graph_PlotAreaMouseLeftButtonUp(object sender, MouseButtonEventArgs e) { Point mousePos = e.GetPosition(graph); Point screenPos = graph.GetPlotAreaPosition(e); IEnumerable<object> children1 = graph.GetChildrenAtPoint(mousePos); IEnumerable<object> children2 = graph.GetChildrenAtPoint(screenPos);
I tried both mouse position and PlotAreaPosition but the two collections are always empty, also if I click on a Range Annotation
Solved! Go to Solution.
10-15-2012 11:07 AM
I was able to reproduce the issue you were seeing, and confirmed there is a bug in our code that prevents annotations from appearing in hit test results. We have created a work item to fix this issue.
To workaround this, here is an example of how you can perform manual hit testing for a RangeAnnotation
in a graph configured with double
horizontal and vertical axes:
double[] dataValue = graph.ScreenToData(plot, screenPos).Cast<double>().ToArray();
foreach( var rangeAnnotation in graph.Children.OfType<RangeAnnotation>() ) {
var horizontalRange = (Range<double>)rangeAnnotation.HorizontalRange;
var verticalRange = (Range<double>)rangeAnnotation.VerticalRange;
if( horizontalRange.Contains(dataValue[0])
&& verticalRange.Contains(dataValue[1]) ) {
// matching range annotation found
10-24-2012 10:22 AM
Problem Solved? If so, please set Phansen answer as the correct one.
Thanks.
Mattia
04-05-2013 12:34 PM
Just wanted to let you know this issue (#374462) was fixed in the Measurement Studio 2013 release.
