02-15-2017 07:42 AM
I have problem with task. This is my code:
I initialize the task.
try { for (byte i = minRange; i < maxRange; i++) { if (pinInit[i]) { digitalOutputWriteTask[i].Dispose(); } using (digitalOutputWriteTask[i] = new Task()) { digitalOutputWriteTask[i].DOChannels.CreateChannel(strDevice(i), "", ChannelLineGrouping.OneChannelForEachLine); digitalOutputWriteTask[i].Control(TaskAction.Verify); digitalOutputWriteTask[i].Start(); writer[i] = new DigitalSingleChannelWriter(digitalOutputWriteTask[i].Stream); //create writer pinInit[i] = true; } } }catch (Exception ex){ Console.Out.WriteLine(ex.Message); return false; }
I have writeDO method in my class:
public bool writeDO(byte pin, bool state) { if (pinInit[pin]) { try { writer[pin].WriteSingleSampleMultiLine(true, arrayToSend(1, state)); return true; } } catch (Exception e) { Console.Out.WriteLine(e.Message); return false; }
I have Exception "NationalInstruments.DAQmx.DaqException: Task specified is invalid or does not exist.".
What's the problem??
Thanks in advance
02-16-2017 09:51 AM
Hi chino5.
did you already check the device name in MAX? Remember that you need to specify the correct device name to create a new phisical channel. Again, If you want to use a task to acquire or generate signals, the task needs to be created in MAX as well. Task's names in your code must match the ones in MAX.
regards,
Stefano
