I like the immediate update feature of the graph because - when turned
off - the graph subsumes several updates, conserving CPU resources.
However, heavy plotting will overcharge the CPU or the GUI is not responsible anymore.
Is it possible to tune the load balancing mechanism inside the graph to further limit the performance of graph drawing to say 50% of the CPU power in order to always have a responsible application?
If the answer is no, I assume that the application which uses the graph is obliged to implement its own load balancing whenever it wants to plot much data.
Christian
