Hello:
Problem:
I'm running sample "ContAcqVoltageSamples_IntClk" for C#.
It works OK when "Samples for channel <= 100,000.
When I'm trying to read more then 100,000, for example 100,001
it's stop responding.
"Help" explains that for sample rate 10,000 - 1,000,000 NI-DAQ uses buffer 100,000.
I tried to set
myTask.Stream.Buffer.InputBufferSize = 200000;
but it didn't work
Q1: How can i read more then 100,000 samples per channel ?
Q2: How can i read more then 100,000 sample per channel
when using two channels "Dev1/ai0" and "Dev1/ai1"
Thank you
