reading Ni-Daq continuously in C#
I'd like to write a little C# code that reads data from a NiDaq Analog Input channel continuously at lets say 500 samples per second and add them to a buffer. This sampling may go on and on for a few hours or even a day.
One way that came to my mind (I had previously done this but I only needed snap shots of data every few seconds) that I had previously implemented is to have a thread that has a while loop with a delay of 2ms and inside of that loop I read the NiDaq channel using: "analogReader.BeginReadWaveform(...)"
But the way I have current system implemented is by triggering "analogReader.BeginReadWaveform(...)" and then firing an Asynch call back when the read is finished seems to be very complicated specially for a high speed application like this.
Is there an example that shows how to read one teeny tiny sample every couple of milliseconds and add it to a buffer without all this events and callbacks and asynch blah blah that can slow down a time sensitive sampling?
(6,236 Views)
Hatefk,
Are you wanting to analyze this data in real-time? Or is some delay in the analysis ok, provided the sampling intervals are constant?
(6,195 Views)
The data needs to be analyzed in real-time and delays are not acceptable.
But I have started looking at this example: "AcqMultVoltageSamples_SWTimed" which seems to be ok.
Thanks OlliesCamel for the reply.
(6,184 Views)
I'm glad you found a solution, but would like to emphasize that a real-time OS would be incredibly beneficial for this application. Otherwise you are certainly going to see jitter of more than 2ms.
(6,163 Views)
Thanks but the system needs to run under windows.
(6,160 Views)
Dear Alan,
Can you kindly provide me the source , I also want this for a high speed application with PCIe  6321. Please help me
(2,062 Views)
