Thanks looking into the problem. Here's some more information.
no. 1: When I installed WiX, there was a problem at the end of installation... I captured the error message so you can look at it. The same error occured when I uninstalled WiX as well.
Here's the error message from Debug: An unhandled exception of type 'System.IO.FileNotFoundException' occurred in NationalInstruments.MeasurementStudio.dll
Additional information: Could not load file or assembly 'NationalInstruments.MeasurementStudio.Interfaces80, Version=8.0.20.312, Culture=neutral, PublicKeyToken=4544464cdeaab541' or one of its dependencies. The system cannot find the file specified.
no. 2: After I downloaded WiX, I was going through this tutorial, http://www.tramontana.co.hu/wix/lesson1.php; downloaded the example, SampleFirst in "C:\WiX\" directory. In order to create a MSI using SampleFirst, one must first change the invalid GUID in the file prior compilation. So I used GUID created from a GUID generator and replaced the invalide GUID. Then I used MS-DOS and and used their compiler and linker (light and candle) to create a SampleFirst MSI file.
I'll attached the edited SampleFirst.wxs file, SampleFirst.wixobj and SampleFirst.msi file because it's the first and only place where I edited GUID.
no. 3: Environment: Microsoft Windows XP Professional 2002 Version 5.1.2600 Service Pack 2 Build 2600 and Microsoft Visual Studio 2005 Professional Edition Version 8.050727.762 SP (.050727-7600)
Thanks & Good Luck
Message Edited by ictoan on 09-21-2007 08:15 AM
