Hi all,
I have a vi that takes a set of input values and calculates the number of peaks that occur. It then calculates the time that has passed between the occurence of two peaks. I have set a scale for the time period.i.e. if the time period is between 1 and 1000ms the scale is 1, if the time period is between 1001 and 2000ms scale is 2 and so on. I have set these conditions in a formula node and connected the output to a meter. My problem is that, if the first time scale is 1, and the second time scale is 2, the meter goes down to 0 from 1 and then moves back to 2. I would like to know, how I can prevent the scale from moving down to zero each time and only move from 1 to 2.Hope I was clear.
Kindly help me out.
Thanks and regards.
