07-04-2014 01:19 PM
Does anyone know a path to porting a VB.net application which uses measurement studio to a mac?
Also, if I were to create a labview application instead, would that easily port to a mac?
bartj
07-04-2014 03:00 PM
The easier is to use LabVIEW.
07-07-2014 12:09 PM
bartj,
do you still plan to make .net calls if you opt to create a labview application? if so, you'd still run into issues porting to a mac os. here's more information on porting vis among platforms:
http://zone.ni.com/reference/en-XX/help/371361H-01/lvconcepts/porting_among_platforms/
another option would be to trying using the mono framework. it is software platform designed to help create cross platform applications
http://www.mono-project.com/Main_Page
07-07-2014 11:27 PM
Do you know if anyone has had sucess using the mono framework while incorporating measurement studio in the project? Specifically the measurement studio graph control is of interest.
bartj
07-08-2014 01:32 PM
bartinoregon,
I just looked futher into incorporating the mono frameowrk with measurement studio and it turns out the two are not compatible. The underlying DLL called to perform the appropriate functionality is a C++ library not compatible with Mono. I apologize for the misleading information in my previous message.
