08-30-2007 11:57 AM
08-30-2007 12:26 PM
Hi
unimaginative,
If you have developed a C# application that is referencing the NI-488.2
assembly and you are now wanting to distribute that application to different
locations, you must do 2 things:
1) Ensure all the appropriate files for your C# application are installed onto
the target computer. I would suggest creating an installer in Visual Studio
that grabs all the dependencies for you automatically. This will include the
NI-488.2 assembly. I would check out the Deploying Measurement Studio
Applications help topic in the NI Measurement Studio Help. This
section tells you what merge modules should be included in your application for
correct distribution. I believe these topics should appear even if you don't
have Measurement Studio installed.
2) Install the appropriate driver on those target systems. In this case, you
must install the NI-488.2 driver on those systems you are deploying to. Without
the underlying driver components, your application will not run. The NI-488.2
assembly calls into these underlying driver DLLs so its needs them at
runtime. When you install the NI-488.2 driver, you don't need the
Language Support options since that is for development purposes.
Hope this helps!
Best Regards,
08-30-2007 01:37 PM
08-30-2007 02:24 PM
09-25-2007 10:00 AM
09-25-2007 12:01 PM
