Hi Alexaver,
A good start would be one of the examples:
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNET2.0\Analog Out\Generate Voltage\ContGenVoltageWfm_IntClk\cs
There is a great example in labview which shows how to do this, it can be found
here. Look at the property nodes they modify to do this, you will use the same property nodes.
This will be a significant programming challenge if your are new to DAQmx and .NET, please understand the example before taking this on... There are good resources here on the forums and
in the
Developer Zone.Best regards,
MatthewW
