01-14-2014 03:36 AM
How to change this heavy yellow color to something more transparent?
01-14-2014 10:05 AM
Currently, there is no property available to customize the color of the interaction visual. I have created a task to add this feature.
As a workaround, you can use the attached custom interaction as a wrapper around the built-in graph interactions to specify custom brushes for the stroke and fill:
var customInteraction = new CustomInteraction( GraphInteraction.Zoom );
customInteraction.SelectionStroke = Brushes.Green;
graph.DefaultInteraction = customInteraction;
01-16-2014 03:29 AM
You are the best, man!
08-11-2015 12:54 PM
Just wanted to let you know that we added the SelectionFill
property in the Measurement Studio 2015 release.
