higher version than referenced assembly
Getting the following error:
Assembly 'NationalInstruments.DAQmx, Version=14.1.45.13, Culture=neutral, PublicKeyToken=4febd62461bf11a4' uses 'NationalInstruments.Common, Version=13.0.40.190, Culture=neutral, PublicKeyToken=dc6ad606294fc298' which has a higher version than referenced assembly 'NationalInstruments.Common, Version=13.0.40.188, Culture=neutral, PublicKeyToken=dc6ad606294fc298'
NI 14.1; MeasurementStudio2013; VisualStudio2012; Windows 8.1
(5,160 Views)
Accepted by Vibhav92
Hi Vibhav92,
Could you verify if 13.0.40.190 version (or higher) of NationalInstruments.Common.dll is present on your system (i.e in the .NET GAC folder and Mesurement Studio 2010 folder).
.NET GAC folder: C:\Windows\Microsoft.NET\assembly\GAC_MSIL
Measurement Studio 2010 folder: C:\Program Files (x86)\National Instruments\MeasurementStudioVS2010\DotNET\Assemblies (on 64-bit machine)
If yes, please delete the current reference to NationalInstruments.Common.dll in your Visual Studio 2012 project and re-add the reference to NationalInstruments.Common.dll reference using the Add Reference dialog of Visual Studio 2012 in your project. Make sure the reference to NationalInstruments.Common.dll in your Visual Studio 2012 project is 13.0.40.190 or higher.
- Raghavendra
(5,154 Views)
It worked for me. Although in my case DAQmx is 20.7 and Common is 19.1
(1,494 Views)
