08-12-2014 08:23 AM
Hi Everyone,
I have a 64 bit .NET project that uses the NationalInstruments.Analysis.Enterprise assembly. When I try to run the application, I get the following error:
Could not load file or assembly 'NationalInstruments.Analysis.Enterprise, Version=13.0.40.242, Culture=neutral, PublicKeyToken=dc6ad606294fc298' or one of its dependencies. The system cannot find the file specified.
I already included the following merge modules in my installer as per this link
mkl64.msm
MStudioCommon.2010_x64.msm
MStudioEnterpriseAnalysis.2010_x64.msm
nianlys_x64.msm
niMetaUtils.msm
Microsoft_VC100_CRT_x64.msm
After the first time it failed, I noticed that the MetaUtils merge module had a 64 bit version, so I included that as well on the off chance there was a typo in the earlier link. Unfortunately I still get the same error.
Is there something else I'm missing?
-Gary
08-12-2014 09:17 AM
Targeting Client Profiles is not supported. Targeting the .NET Framework 4 Client Profile is the default for new projects, so you must change the target through the Project Properties window, as shown in the following screenshot.
