07-24-2006 02:47 PM
07-25-2006 04:21 PM
07-25-2006 06:30 PM
Adam,
Thanks for trying. The article doesn't have much that is applicable. I am not using an external trigger and the trigger rate is explicitly set at the beginning in the task. The problem can easily be reproduced by setting up a task in MAX.
I am solving the problem temporarily or maybe permanently by using separate tasks for each module. My problem is, I believe, a bug or an inefficieincy in DAQmx 8.1.
Dave
