08-02-2016 09:46 PM
I am working on a project where I need to use C# to both write a waveform (could be sinusoidal, square, etc.) on one of the analog out channels and then read the waveform on one of the analog in channels and for certain monetary reasons (I'm just a student) I cannot really afford to buy MeasurementStudio.
So, is anyone aware of a fully documented API for the DAQ-MX C# plugins? I've looked around a fair amount and cannot really find anything.
08-03-2016 05:31 PM
Hi mwalk99,
You don't need MeasurementStudio in order to use the DAQmx driver in C#. All you need is the .NET support added during installation. After you install the .NET support, you can access the help documentation installed with the driver as well as examples on how to perform various tasks in DAQmx. Measurement Studio basically adds extra UI options as well as an advanced math library, but this shouldn't keep you from simply sending and receiving a waveform using DAQmx as long as your device has the capability.
08-03-2016 06:38 PM
Thank you! I guess my confusion stemmed from there not being a standard API that you would find just about everywhere else. Now to figure out how to read and send data at the same time...
