11-06-2006 11:23 AM
11-07-2006 12:15 PM - edited 11-07-2006 12:15 PM
Perhaps this question might be better asked on the DAQ forums. However, I did look into this a bit for you. First of all, there is a lite version of the DAQmx driver: the DAQmx runtime driver. The installation files for this driver are available at ftp://ftp.ni.com/support/daq/pc/ni-daq/daqmx/8.3/Run-time%20Engine/Runtime/. As far as the limitations of this, I am not sure what is different between the runtime and the full version other than the fact that the run-time engine is much smaller (~150 MB). In any case, you could send out the installation files and run the file "setup.exe" either from the full version installation or the runtime installation (located at http://digital.ni.com/softlib.nsf/websearch/7FEAEE6A4B4AA836862571C00064E6CA?opendocument&node=13206... or ni.com/support).
Secondly, if you aren't aware, you can include external installations in your C# build project so that they will be installed when installing your application. As far as how you can do this, I would recommend checking the MSDN or Visual Studio's help, or perhaps a C# forum online.
Hope this information is helpful.
Message Edited by AndrewMc on 11-07-2006 12:18 PM
11-07-2006 04:34 PM
Version |
Removed Component |
Full |
Full Support |
Runtime |
ADE Support |
Runtime 2 |
DAQ Assistant |
Runtime 3 |
NI-DAQmx Documentation |
Runtime 4 |
Real-Time support |
Runtime 5 |
MAX Interface |
11-07-2006 05:17 PM
Howdy grisha,
In addition to what Andy and Tom mentioned, I would also suggest taking a look at this forum which discusses implementations of distributing DAQmx with a Visual Studio application. Option 2 on that list can also be changed to LabVIEW if you have LabVIEW installed.
Currently, we provide merge modules for Measurement Studio .NET (all located in Program Files\Common Files\Merge Modules) and ActiveX components. One area that R&D is looking into is developing DAQmx driver merge modules. This would allow you to just include these merge module in your Visual Studio setup project and not have to install the DAQmx driver separately.
For more information on deploying Measurement Studio applications, check out the KnowledgeBase Distributing Measurement Studio Applications in Microsoft Visual Studio 2003/2005 and the Measurement Studio help topic "Deploying Measurement Studio Windows Applications".
Hope this helps!
Best Regards,
11-09-2006 01:27 PM
The link to the DAQmx runtime installations has been updated. Please refer to this link: http://digital.ni.com/softlib.nsf/websearch/1cafec237c5d5d488625722000531213 to find the installation files for the DAQmx 8.3 Run-time Engines.
This page also contains a brief summary of each version of the Run-time Engines and installation instructions.
Grisha, please let us know if you encounter any obstacles with this advice.
