09-10-2015 09:39 PM
I need exactly the functionality cwgraph in ms6 had. The .NET graph control is not adequate. I located cwui.ocx in the windows x86 sysWOW folder which means it is a 32bit activex control. I registered it successfully .NET creates a wrapper for it so it can be used in VB.NET. Question is, can i use it in a 64 bit VB.NET application? I was able to use it in an anyCPU program, but got an error like import failed when I tried to drag it on a 64 bit windows form. So....can it be used in a 64 bit VB.NET application?
thanks,
sb
09-12-2015 04:34 PM
09-15-2015 11:42 AM
Daniel,
thank you for the response. I was able to get the CWGraphControl to work as I need it to. I have yet to try out the scattergraph control which is also in my application.
thanks!
sb
