I have a graph with several scatter plots. Each plot has the same scale X/Y axes. When I zoom, they always scale together, or so I though. I discovered that when the range of the X Axis is large (> 10000), the plots don't all scale the same.
I need to know why all plots don't zoom the same amount when the ranges are all the same, and a solution to force them to stay synchronized. Note, this is NOT the problem of synchronizing two graphs. I know how to do that. This is two plots on one graph. Trying to sync them with events would likely cause undo problems, so I want to understand what is going on so I can find a potential solution.
Mike
