06-05-2007 08:36 AM
06-06-2007 11:30 AM
06-06-2007 08:43 PM
06-07-2007 09:28 AM
06-07-2007 11:21 AM
06-08-2007 02:15 PM
Hi John,
What DAQ device do you have? If you are sampling each channel at approximately 20KS/s, then the rule of thumb is to read from the buffer 10 times a second. This means that your samples to read (buffer size) should be 2KS/s.
There are many reasons that you are getting this error. You may not be reading the data off the buffer fast enough. There are two typical causes for this which are not setting up your buffer correctly or taking too long doing other processes in between reads. If you set your buffer up as explained earlier and you wait two seconds in between calling the DAQmx Read, then you will overrun your buffer.
06-11-2007 06:49 PM
06-23-2007 09:35 AM
06-23-2007 11:13 AM
