05-11-2017 09:02 AM - edited 05-11-2017 09:03 AM
I am working on some project where I need to use NI-DAQmx to create application using Visual C# .NET without Measurement Studio.
I have installed the latest NI-DAQmx 16.1.0., I managed to install .Net Framework 4.5.1 language support as well as the correspondent examples. But I can not find any DAQmx .NET and API Documentation.
Spent a lot of time on the forum and NI site and cannot not find anything.
Please help
Thank you
05-12-2017 04:05 PM
Hey sofial65,
I'm assuming that if you have gotten the examples installed, then you have been playing around with them to see how you can build off of them.
When searching online, I found a similar discussion post, and Johnathan has a pretty good reply in the link below:
Where are DAQmx .NET Documentat
I also found this document that has some basic examples:
Using NI-DAQmx in Text Based Programming Environments
http://www.ni.com/tutorial/5409/en/#toc4
This may also be useful:
NI-DAQmx .NET Class Library Help for Visual Studio 2010
http://zone.ni.com/reference/en-XX/help/370473H-01/
Is this the kind of information that you are looking for?
Best Regards,
Alyssa H.
