Hi kirko7,
The optional IOpComparison argument is for cases when you wish to specify a different or custom comparer for the TData values within that range. The documentation for this can be found in the Measurement Studio help within Visual Studio, including full documentation on the members of each class. I've linked the documentation for that specific Range constructor you are referencing, which describes IOpComparison as the instance of a comparer used to compare minimum and maximum. This would be useful in cases where the default comparison method would not suffice for your application when determining if something is within range or not.
Unfortunately I could not track down an example or a link to a help page, but you should be able to find the same documentation I looked at in the Measurement Studio Help from within Visual Studio. Just search for "Range(TData)" to find the Range Constructor page, and you should be able to navigate from there to the specific constructor and documentation on IOpComparison.
Charlie J.
