08-03-2011 03:17 AM
I have moved my application from Visual Studio 2008 and NET3.5 to Visual Studio 2010 and NET4.0. Now, I'm having problems with waveforms and
references. Here is error message I got when I build and run application.
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.TypeInitializationException: The type initializer for 'NationalInstruments.UI.Internal.WaveformPlotElement' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'NationalInstruments.Common.Native.dll' or one of its dependencies. The specified module could not be found. at NationalInstruments.PrecisionTimeSpan.FromSeconds( Double value) at NationalInstruments.UI.Internal.WaveformPlotElemen t..cctor() --- End of inner exception stack trace --- at NationalInstruments.UI.Internal.WaveformPlotElemen t..ctor(ControlElement parent, Object obj) at NationalInstruments.UI.WaveformPlot.CreateElement( ) at NationalInstruments.UI.ControlEntity..ctor() at NationalInstruments.UI.Plot..ctor() at NationalInstruments.UI.XYPlot..ctor() at NationalInstruments.UI.WaveformPlot..ctor() at IBEKOPOWERAB.Aplikacija.CATApp.CATViewer.Initializ eComponent() in D:\Development\New_workspace\DV-Win\trunk\4.0.2a\K vTeamApplication\CATApp\CATViewer.designer.cs:line 145 at IBEKOPOWERAB.Aplikacija.CATApp.CATViewer..ctor(Dou ble[] Main1r, Double[] Main2r, Double[] Main3r, Double[] Main4r, Double[] Main5r, Double[] Main6r, Double[] Analog1r, Double[] Analog2r, Double[] Aux1r, Double[] Aux2r, Double[] Aux3r, Double[] closingCurrentR, Double[] breakingCurrentR, Double[] motionR, TipUredjajaEnum tipUredjaja, String parametri, String[] numerickiRezultati, String imeFilea, List`1 lista, DataSet numerika, DataTable dtTestInfo, Double koeficijentAnalog, String tipTransducera, String koeficijentStrujnaKlijesta, String fazaTransduceraIn, String brPrekidnihMjesta) in D:\Development\New_workspace\DV-Win\trunk\4.0.2a\K vTeamApplication\CATApp\CATViewer.cs:line 368 at IBEKOPOWERAB.Aplikacija.CATApp.catviewerParent.ope nDemo() in D:\Development\New_workspace\DV-Win\trunk\4.0.2a\K vTeamApplication\CATApp\catviewerParent.cs:line 190 at IBEKOPOWERAB.Aplikacija.CATApp.CATForm.btnStartTes t_Click(Object sender, EventArgs e) in D:\Development\New_workspace\DV-Win\trunk\4.0.2a\K vTeamApplication\CATApp\CATForm.cs:line 2452 at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v4.0.30 319/mscorlib.dll ---------------------------------------- DV-Win Assembly Version: 4.0.2.0 Win32 Version: 4.0.2 CodeBase: file:///C:/Documents%20and%20Settings/Adnan/Deskto p/Release/DV-Win.exe ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL /System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e0 89/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL /System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/Sys tem.Drawing.dll ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL /System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- dvbll Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Adnan/Deskto p/Release/dvbll.DLL ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL /System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a 3a/System.Configuration.dll ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL /System.Core/v4.0_4.0.0.0__b77a5c561934e089/System .Core.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL /System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System. Xml.dll ---------------------------------------- dvcomm Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Adnan/Deskto p/Release/dvcomm.DLL ---------------------------------------- FTD2XX_NET Assembly Version: 1.0.6.0 Win32 Version: 1.0.6.0 CodeBase: file:///C:/Documents%20and%20Settings/Adnan/Deskto p/Release/FTD2XX_NET.DLL ---------------------------------------- NationalInstruments.UI.WindowsForms Assembly Version: 9.0.40.292 Win32 Version: 9.0.40.292 CodeBase: file:///C:/Documents%20and%20Settings/Adnan/Deskto p/Release/NationalInstruments.UI.WindowsForms.DLL ---------------------------------------- NationalInstruments.UI Assembly Version: 9.0.40.292 Win32 Version: 9.0.40.292 CodeBase: file:///C:/Documents%20and%20Settings/Adnan/Deskto p/Release/NationalInstruments.UI.DLL ---------------------------------------- NationalInstruments.Common Assembly Version: 9.0.40.362 Win32 Version: 9.0.40.362 CodeBase: file:///C:/Documents%20and%20Settings/Adnan/Deskto p/Release/NationalInstruments.Common.DLL ---------------------------------------- System.Web Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/S ystem.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.We b.dll ---------------------------------------- Accessibility Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL /Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Acce ssibility.dll ---------------------------------------- System.Data Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/S ystem.Data/v4.0_4.0.0.0__b77a5c561934e089/System.D ata.dll ---------------------------------------- System.Numerics Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL /System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/Sy stem.Numerics.dll ---------------------------------------- DotNetMagic Assembly Version: 6.0.0.0 Win32 Version: 6.0.0.0 CodeBase: file:///C:/Documents%20and%20Settings/Adnan/Deskto p/Release/DotNetMagic.DLL ---------------------------------------- System.Design Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL /System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/Syst em.Design.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
It is same with x32 and x64 machines. I have tried to build it for x86, x64 and AnyCPU platform but unfortunately without success.
In references I have included
Help, advice, anything please?
Solved! Go to Solution.
08-04-2011 04:18 AM
During testing I have found that even when I make project with just one form and just with waveform element on it, on Windows XP with NET4.0 full it throw an exception ( I have tested it on 3 different computers). With Windows 7 it works just fine. When i run it on XP where I have installed Visual Studio 2010, it works just fine, too. In attachment there is simple program with one form and one waveform on it and printscreen of exception message. It could be some kind of bug in MS2010?
It is quite urgent so if someone have an idea - please share it with me.
Thank you in advance.
Greetings
08-04-2011 09:22 AM
Hello -
I think you likely need to install the Microsoft Visual C++ 2010 Redistributable Package. Give that a try and let us know if it resolves things for you.
NickB
08-05-2011 02:57 AM
Dear NickB
I hope that someday I will have a chance to buy you a beer
. Thank you very much, you saved me. It works with MSVC2010 redist.
Greetings!
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
