Want to print grid lines along with axis and scatterplot
Hi Wilfried,
I was able to reproduce the issue on one computer up here but not another, both running 8.1.1 as reported in the Measurement Studio Help>>About dialog. Which version of the NationalInstruments.UI assembly do you see in:
  • Your project references
  • <MeasurementStudio>\DotNET\Assemblies\Current
  • C:\WINDOWS\assembly
I have attached the program I used to reproduce the issue, could you attach yours?
Message 11 of 13
(1,243 Views)
Hello James,
the versions are as follows:
  • My project references
  • --> 8.1.20.377
  • --> 8.1.20.377
  • --> 8.1.20.377
The slightly modified printing example which I use to reproduce this issue is attached.
Regards
Wilfried
Message 12 of 13
(1,239 Views)
Hi Wilfried,
This was reported to R&D (# 4D4BF0ZL) for further investigation. A possible workaround is to just call the Draw() method on the graph, but this will print everything. We tried this workaround here and the gridlines looked fine. Thanks for the feedback!
Message 13 of 13
(1,231 Views)
