08-25-2015 09:09 AM
This code worked at MS 2013:
public class MyGeneralValueFormatter : GeneralValueFormatter
return Engineering.ToFormattedString(Convert.ToDouble(value), this.Format, _units);
protected override UIElement VisualizeCore<TData>(TData value, ValuePresenterArgs args, UIElement existingVisual)
UIElement element = base.VisualizeCore<TData>(value, args, existingVisual);
if (args.Context is Axis<TData>)
var axis = (Axis<TData>)args.Context;
if (axis.Orientation == System.Windows.Controls.Orientation.Horizontal)
if (_showOnlyMinMaxAtX)
Range<TData> range = axis.Range;
var comparer = range.Comparer;
RelativeAlignment alignment =
comparer.Compare(range.Minimum, value) == 0 ? RelativeAlignment.Near :
comparer.Compare(range.Maximum, value) == 0 ? RelativeAlignment.Far :
RelativeAlignment.Center;
//RegionPanel.SetRelativeHorizontalAlignment(element, alignment);
element.Opacity = comparer.Compare(range.Minimum, value) == 0 || comparer.Compare(range.Maximum, value) == 0 ? 1.0 : 0.0;
else
element = new Viewbox { MaxWidth = 60, Width = 60, Stretch = System.Windows.Media.Stretch.None, Child = element };
return element;
1. This doesn't even compile:
2. This crashes with error: Specified element is already the logical child of another element. Disconnect it first.
Solved! Go to Solution.
08-25-2015 10:17 AM
Hi, eugenem
I can address one of your concerns immediately. In Measurement Studio 2015, RegionPanel was changed to RelativePanel, which is why that line no longer compiles.
To address your other concern, I will need more context for this code. Syntactically, I don't believe your code (as is) would have compiled in any version of Visual Studio. It is also unclear how the value formatter class relates to the VisualizeCore<TData> override method. Can you please provide a more complete snippet? Please see the following copy of the code you provided, where I have added comments with questions. I also highlighted the place I changed RegionPanel to RelativePanel.
// This is a class definition. Why is it returning a value? public class MyGeneralValueFormatter : GeneralValueFormatter { return Engineering.ToFormattedString(Convert.ToDouble(value), this.Format, _units); } // Where does this method belong? Currently it does not have a containing class. protected override UIElement VisualizeCore<TData>(TData value, ValuePresenterArgs args, UIElement existingVisual) { UIElement element = base.VisualizeCore<TData>(value, args, existingVisual); if (args.Context is Axis<TData>) { var axis = (Axis<TData>)args.Context; if (axis.Orientation == System.Windows.Controls.Orientation.Horizontal) { if (_showOnlyMinMaxAtX) { Range<TData> range = axis.Range; var comparer = range.Comparer; RelativeAlignment alignment = comparer.Compare(range.Minimum, value) == 0 ? RelativeAlignment.Near : comparer.Compare(range.Maximum, value) == 0 ? RelativeAlignment.Far : RelativeAlignment.Center; RelativePanel.SetRelativeHorizontalAlignment(element, alignment); element.Opacity = comparer.Compare(range.Minimum, value) == 0 || comparer.Compare(range.Maximum, value) == 0 ? 1.0 : 0.0; } } else { element = new Viewbox { MaxWidth = 60, Width = 60, Stretch = System.Windows.Media.Stretch.None, Child = element }; } } return element; } }
08-25-2015 10:24 AM
sorry, I've deleted too much of the class. there is the full version:
public class RCAGeneralValueFormatter : GeneralValueFormatter { private string _units; private bool _showOnlyMinMaxAtX; public RCAGeneralValueFormatter(string format, string units, bool showOnlyMinMaxAtX) : base(format) { _units = units; _showOnlyMinMaxAtX = showOnlyMinMaxAtX; } protected override string FormatCore<TData>(TData value, ValuePresenterArgs args) { if (args.Context is Axis<TData>) { var axis = (Axis<TData>)args.Context; if (axis.Orientation == System.Windows.Controls.Orientation.Horizontal) { Range<TData> range = axis.Range; var comparer = range.Comparer; if( comparer.Compare(range.Minimum, value) != 0 && comparer.Compare(range.Maximum, value) != 0) return Engineering.ToFormattedString(Convert.ToDouble(value), this.Format, ""); } } return Engineering.ToFormattedString(Convert.ToDouble(value), this.Format, _units); } protected override UIElement VisualizeCore<TData>(TData value, ValuePresenterArgs args, UIElement existingVisual) { UIElement element = base.VisualizeCore<TData>(value, args, existingVisual); if (false && args.Context is Axis<TData>) { var axis = (Axis<TData>)args.Context; if (axis.Orientation == System.Windows.Controls.Orientation.Horizontal) { if (_showOnlyMinMaxAtX) { Range<TData> range = axis.Range; var comparer = range.Comparer; RelativeAlignment alignment = comparer.Compare(range.Minimum, value) == 0 ? RelativeAlignment.Near : comparer.Compare(range.Maximum, value) == 0 ? RelativeAlignment.Far : RelativeAlignment.Center; //RegionPanel.SetRelativeHorizontalAlignment(element, alignment); element.Opacity = comparer.Compare(range.Minimum, value) == 0 || comparer.Compare(range.Maximum, value) == 0 ? 1.0 : 0.0; } } else { element = new Viewbox { MaxWidth = 60, Width = 60, Stretch = System.Windows.Media.Stretch.None, Child = element }; } } return element; } }
08-25-2015 02:49 PM
Thank you for posting the rest of the code.
It looks like instead of using your override for VisualizeCore<TData>, you can make use of the new properties, RangeLabeledDivisions.MaximumLabelAlignment and RangeLabeledDivisions.MinimumLabelAlignment. For example:
<ni:Graph> <ni:Graph.Axes> <ni:AxisDouble Orientation="Horizontal"> <ni:AxisDouble.MajorDivisions> <ni:RangeLabeledDivisions MaximumLabelAlignment="Far" MinimumLabelAlignment="Near" /> </ni:AxisDouble.MajorDivisions> </ni:AxisDouble> </ni:Graph.Axes> </ni:Graph>
As for creating a new ViewBox, is there a reason you don't just set the UIElement properties directly on element? It seems like setting the MaxWidth on element would have the same effect as what you are doing there.
