WPF Slider - Change ScaleKind programatically in C#
How do I go about changing the ScaleKind programatically in C#? The WPF properties look simple enough but I don't see a way to map this to C# as SkaleKind doesn't appear anywhere in the list of "intellisense" options.
<ni:SliderDouble...
  <ni:SliderDouble.Scale>
    <ni:NumericScale ScaleKind="Linear"/>
  </ni:SliderDouble.Scale>
or
    <ni:NumericScale ScaleKind="LogarithmBase10"/>
(6,731 Views)
Accepted by FoxGrove
If your XAML is setup like your first example, you can give your NumericScale a name and assign the value directly in code:
    XAML
    <ni:SliderDouble ...>
            <ni:NumericScale x:Name="scale" ScaleKind="Linear" />
    </ni:SliderDouble>
    Code
    scale.ScaleKind = RangeScaleKind.LogarithmBase10;
If naming the scale is not an option, then you can cast the Scale property on the slider to the appropriate type:
    var scale = (NumericScale)slider.Scale;
~ Paul H
(6,725 Views)
Thanks again Paul! In C# I am now able to do this:
((NumericScale)slideDemo.Scale).ScaleKind = m_ScaleKind;
(6,722 Views)
