WPF Intensity Graph gridlines not visible on plotted data
Hi, I need to break up my intensity graph data into a visible grid.  Please advice on how this can be accomplished.
Thank you
(5,373 Views)
Although you can configure the grid lines to appear above the plots, to draw in between the data points you will want a custom renderer. I have attached an example grid renderer, which you can customize to fit the data you display. If you add an instance of GridRenderer to the Children collection on your graph, it will draw grid lines for each axis passed to the constructor.
~ Paul H
(5,332 Views)
Hello, could you explain how you can configure the grid lines to appear above the plots?
- Henry
(1,208 Views)
To get the regular grid lines to appear above the plots, you use the same LayeredGraph.Position attached property as the GridRenderer example above. The only trick is this property needs to be set on the renderer for the GridLines, which requires a little code:
public class CustomGridLines : GridLines {
    public override GridLinesRenderer<TData> TryGetRenderer<TData>( IDataMapper<TData> dataMapper ) {
        var renderer = base.TryGetRenderer( dataMapper );
        if( renderer != null )
            LayeredGraph.SetPosition( renderer, GraphLayerPosition.AbovePlots );
        return renderer;
In your graph axes, use this custom object for the major or minor grid lines to show them above plots.
~ Paul H
(1,192 Views)
