WPF Graph: how to add space between ticks and labels
I would like to know how to set a margin between major tick marks and their labels in a WPF Graph.
Especially in the YAxis, labels are placed very close to the ticks.
(4,134 Views)
Accepted by topic author diluculo
Unfortunately, there is no existing configuration property to add extra space around scale labels. I have created a task to address this in a future Measurement Studio release.
As a workaround, you can use a string format that includes additional whitespace in the result:
    <ni:AxisDouble Orientation="Vertical" ...>
        <ni:AxisDouble.MajorDivisions>
            <ni:RangeLabeledDivisions>
                <ni:RangeLabeledDivisions.LabelPresenter>
                    <ni:GeneralValueFormatter Format="{}{0} " />
                </ni:RangeLabeledDivisions.LabelPresenter>
            </ni:RangeLabeledDivisions>
        </ni:AxisDouble.MajorDivisions>
    </ni:AxisDouble>
If you need finer control, you can create a custom label presenter to add additional space to the generated label visual.
~ Paul H
(4,114 Views)
Paul, thanks for your kind reply.
By adding "VisualizeCore" method into your EngineeringValueFormatter class, I can do what I want.
class EngineeringValueFormatter: ValueFormatter
        protected override UIElement VisualizeCore<TData>(TData value, ValuePresenterArgs args, UIElement existingVisual)
            UIElement element = base.VisualizeCore<TData>(value, args, existingVisual);
            // Add additional space to the generated label visual.
            var axis = (Axis<TData>)args.Context;
            var tb = (TextBlock)element;
            if (axis.Orientation == Orientation.Vertical)
                if (axis.Location == RelativeLocation.Near)
                    tb.Margin = new Thickness(0, 0, 5, 0);
                else if (axis.Location == RelativeLocation.Far)
                    tb.Margin = new Thickness(5, 0, 0, 0);
            else if (axis.Orientation == Orientation.Horizontal)
                    tb.Margin = new Thickness(0, 0, 0, 0);
                    tb.Margin = new Thickness(0, 0, 0, 5);
            return element;
(4,077 Views)
Just wanted to let you know that value formatters now include a Padding property (although admittedly not as flexible as your custom code!):
        <ni:GeneralValueFormatter Padding="0,0,5,0" />
~ Paul H
(2,054 Views)
