10-17-2016 08:46 AM
How can i make it, display the curve name in ToolTip, if i moved the mouse over the curve?
Or display the curve name fixedly above the curve?
And, how can i select a curve with mouse click?
Possible?
Tamas
P.S.: VS2013 Community & MS2015 Standard
Solved! Go to Solution.
10-17-2016 11:06 AM
Using the tool tip logic from WPF graph display point value on hover, and the GetPlotAt
function, here is an example that uses mouse clicks to select plots in a graph:
public partial class MainWindow : Window { private Plot _selectedPlot; public MainWindow( ) { InitializeComponent( ); // (Optional) Turn on hit testing for drawn lines, in addition to actual data. graph.HitTestMode = PlotHitTestMode.RenderedInterpolation; // Update tool tips to show quickly and for a long time. ToolTipService.SetInitialShowDelay( graph, 0 ); ToolTipService.SetShowDuration( graph, int.MaxValue ); // Populate graph with example plots and data. graph.BeginInit( ); var plotBrushes = new[] { Brushes.Red, Brushes.Orange, Brushes.Green, Brushes.Blue }; for( int i = 0; i < plotBrushes.Length; ++i ) { string label = "Plot " + (i + 1); var renderer = new LinePlotRenderer { Stroke = plotBrushes[i] }; var plot = new Plot( label ) { Renderer = renderer }; graph.Plots.Add( plot ); graph.Data[i] = new[] { i, i + 1 }; } graph.EndInit( ); // Monitor graph plot area for mouse clicks. graph.PlotAreaMouseLeftButtonDown += OnPlotAreaMouseLeftButtonDown; } private void OnPlotAreaMouseLeftButtonDown( object sender, MouseButtonEventArgs e ) { // Check if a new plot was shown at the current position. Point screenPosition = e.GetPosition( graph ); var plot = (Plot)graph.GetPlotAt( screenPosition ); if( plot == null || plot == _selectedPlot ) return; // De-select the previous plot, if it exists. if( _selectedPlot != null ) { ((LinePlotRenderer)_selectedPlot.Renderer).StrokeThickness = 1.0; ((ToolTip)graph.ToolTip).IsOpen = false; } // Select the new plot, and show a tool tip. _selectedPlot = plot; ((LinePlotRenderer)plot.Renderer).StrokeThickness = 2.0; graph.ToolTip = new ToolTip { Content = string.Format( "'{0}' selected", plot.Label ), IsOpen = true }; } }
Regarding "display the curve name fixedly above the curve", the easiest approach would probably be to use a PointAnnotation
to display a label at a particular position (probably hiding the target and arrow).
10-24-2016 06:29 AM
thanks for your reply!
It's working good!
Tamas
