11-26-2005 12:03 PM
11-28-2005 11:04 AM
10-26-2006 01:57 PM
Hi Chris,
I am currently working on converting an image analysis application using IMAQ Vision from Visual Basic 6 to Visual Basic 2005. I was wondering if you decided to complete the migration to VB 2005 and, if so, if you have noticed any improvements in the performance of your software.
Naveen
10-26-2006 03:11 PM
Dear Naveen,
No, Visual Studio 2005 came too late for that particular project - also I wanted to make a profit and deliver on time so VB6 was the low risk option.
It all worked out fine in VB6.
Am now too busy to learn Visual Studio 2005 until mid next year.
How about you - do you see enough advantages to justify the migration.
Chris
10-27-2006 11:18 AM
Hi Chris,
I'm still in the process of migrating my application to VB 2005. The project involves real-time image processing for single particle trapping in solution. The multi-threading capabilities of VB 2005 are quite useful, since they allow the image processing and display to be done on separate threads with different priorities. Another major advantage is an improved timer, the new Stopwatch control, that uses the system clock to achieve very high resolution timing. I also appreciate the object-oriented nature of VB 2005, which is useful for writing modular code. When you have time, I think that it might be worth learning more about the language.
Naveen
