05-09-2012 01:04 PM
I am running vb 2005 and I have developed software that uses a NI-DAQ card. When I build my program and install it on the same PC my VB 2005 is on I can see my NI-DAQ card in my program and everything runs well. (The VB 2005 and the installed program are both running on a windows XP Virtual Machine) when I go to install the program on my Windows 7 64 PC (which is the same PC that I am running my VM) I can;t seem to find it in my program.
My question is what would be the difference with why the VM XP machine sees the NI-DAQ card when my vb program is install and why it doesn;t see the NI-DAQ card installed on the Windows 7 64 machine.
The code is how I search and populate the combo box.
Private Sub tmrGetDevices_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles tmrGetDevices.Tick
Me.tmrGetDevices.Enabled = False
Dim mainform As frmMain = Me.MdiParent
Dim oldtstext As String = mainform.toolStripLbl1.Tex
05-10-2012 12:24 PM
What DAQ card are you using? What version of DAQmx do you have on your VM and Windows 7 machine? Also, are you able to communicate with your DAQ card in MAX in Windows 7? Posting your code would be really helpful.
05-10-2012 12:28 PM
I have several calls to an external hardware NI-DAQ card. One call is the code below. When I run my program in the Debug mode I dont have any issues with finding the NI-DAQ device, however when I build the program and run it on another machine I seem to get error or the code below doesn;t execute. I believe it may be my program references or dependencies so I have attached screen shots of both. My question is what am I doing wrong?
I am working with the NI USB 6525. Also it fails on the Function CheckIfNIExists() and the error is the following:
Error Information
Partfile Name = 4.2.0.0
Error Target - CheckIfNIExists
Error Message - Could not load file or assembly 'NationalInstruments.DAQmx, Version=9.5.20.112, Culture=neutral, PublicKeyToken=4544464cdeaab541' or one of its dependencies. An attempt was made to load a program with an incorrect format.
Exception Type - System.BadImageFormatException: Could not load file or assembly 'NationalInstruments.DAQmx, Version=9.5.20.112, Culture=neutral, PublicKeyToken=4544464cdeaab541' or one of its dependencies. An attempt was made to load a program with an incorrect format.
File name: 'NationalInstruments.DAQmx, Version=9.5.20.112, Culture=neutral, PublicKeyToken=4544464cdeaab541'
at LMIObjectLibrary.SequenceMethods.CheckIfNIExists()
at UGI.frmSequenceEditor2.tmrGetDevices_Tick(Object sender, EventArgs e)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace
Imports NationalInstruments.DAQmx
Dim oldtstext As String = mainform.toolStripLbl1.Text
mainform.toolStripLbl1.Text = "Searching for National Instruments Cards - " & oldtstext
Try
MessageBox.Show("In Timer")
If sequenceMethod.CheckIfNIExists Then
sequenceMethod.FillIOCardsWithNI(niCards)
boolNIExists = True
MessageBox.Show("Card Found")
Else
boolNIExists = False
End If
Catch ex As Exception
'MessageBox.Show("Card Not Found")
_TListener.AddMethodError(ex)
End Try
mainform.toolStripLbl1.Text = oldtstext
mainform = Nothing
End Sub
Public Function CheckIfNIExists() As Boolean
Try
MessageBox.Show("Inside CheckIfNIExists")
Dim tmpDevices() As String = DaqSystem.Local.Devices
Return True
Catch fnfex As FileNotFoundException
Return False
' Return False
tlistener.AddMethodError(ex)
End Try
End Function
05-10-2012 12:55 PM
This may have to do with the version of DAQmx you have on both machines. What versions do you have? Are you able to run the code in debug mode on your Windows 7 machine?
05-10-2012 12:58 PM
I am able to run the program and also debug and run the program under the VM XP Pro SP3 machine is where my VS environment is... I look under the add /remove programs on both the VM machine and the Windows 7 64 bit machine and 9.5.0. As for anything else and version number I do not know where to look.
05-10-2012 01:12 PM
When you build your executable, what is your target platform set to? Chances are it is set to "Any CPU". Try setting it to x86, build it and then run it on your Windows 7 machine. This will force it to run in 32-bit mode on a 64-bit machine.
05-10-2012 01:37 PM
OK I do have a lot of other 3rd party software that aren;t giving any errors when I run them on Windows 7 PC.
I did change the x86 plateform and no change still the same error on the Window 7 64 bit machine. I did however try the same (build before the Plateform change on another Windows XP SP3 machine and it gave me the same error.
It is definatly driver related I just dont know where to look.
05-10-2012 01:42 PM
How about you build an installer instead and that way, all needed files are installed on to the machine that tries to run the executable.
05-10-2012 01:45 PM
I could if I knew how...however I do not want to change anything major on the load. Do you have any idead how I can compare the error I am seeing on the Windows 7/XP and which drivers are different from the other Windows XP machine?
05-10-2012 02:25 PM
In Measurement & Automation Explorer, create a technical report. This KB has detailed instructions on how to do that. Do this for both VM and Windows 7 machine. Attach the reports and I will take a look at them.
