Hi Morgram,
thank you for your reply.
i can not define my remote I/o server see my Attachment.
With the siemens opc Scout i can trace my opc item
DemoTemperature ===>
//192.168.8.5/OPC.SimaticNET/S7:[DEMO]DemoTemperature
Furthermore i can not do this with teh NI Server Explorer 2.4.1
-select Netzwekumgebung
-select remote host (IPEPDVWINPLC)
-select OPC.SimaticNet
-->use the Wizard....continue.......continue
--conected to the opc server.....
I can see all all items in the
Name(Device\Item) the c symbol is green (connected) column ...and
in the Item ID column
the value, timestamp and quality columns shows ???
The working VI from the first post uses the old socket library (show
into) , with the actual socket library the VI does not work.....
Achim
