12-21-2006 01:11 PM
12-22-2006 10:30 AM
12-22-2006 10:35 AM
Hi All-
Just to add an additional suggestion- since you mention that you are using an external resistor divider network, you may need to consider the input impedance of the 6009 device (~144kOhm) and it's effect on the operation of your external circuitry. It may be necessary to insert a buffer between your divider network and the input of the 6009.
Hopefully this helps-
01-02-2007 06:33 AM
