05-24-2017 04:39 AM
I'm using NI daq for some measurements and i don't have a clue how to use it with thread and for loop
my point is: i have 3 different frequencies, that stored in array , i need that after clicking a START button, function will generate first frequency and will red it and store data to the file, after this it move to second frequency and to same job, and after this will do measurement with third frequency and stop
Example:
for(int i=0; i< 3; i++)
Measurement function();
I have this code:
//start button function click private void cmd_start_Click(object sender, EventArgs e) { cmd_start.Enabled = false; taskRunning = true; for (int i = 0; i < matrix_data.Count; i++) { // Change the mouse to an hourglass for the duration of this function. Cursor.Current = Cursors.WaitCursor; pass_freq = matrix_data[i].freq; try { // Create the master and slave tasks inputTask = new Task("inputTask"); outputTask = new Task("outputTask"); // Configure both tasks with the values selected on the UI. inputTask.AIChannels.CreateVoltageChannel("Dev1/ai0", "", AITerminalConfiguration.Differential, inputMinValNumeric, inputMaxValNumeric, AIVoltageUnits.Volts); outputTask.AOChannels.CreateVoltageChannel("Dev1/ao0", "", Convert.ToDouble(outputMinValNumeric), Convert.ToDouble(outputMaxValNumeric), AOVoltageUnits.Volts); // Set up the timing inputTask.Timing.ConfigureSampleClock("", Convert.ToDouble(rateNumeric), SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, Convert.ToInt32(samplesNumeric)); outputTask.Timing.ConfigureSampleClock("", Convert.ToDouble(rateNumeric), SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, Convert.ToInt32(samplesNumeric)); // Set up the start trigger string deviceName = "Dev1"; string terminalNameBase = "/" + GetDeviceName(deviceName) + "/"; // outputTask.Triggers.StartTrigger.ConfigureDigitalEdgeTrigger(terminalNameBase + "ai/StartTrigger", triggerEdge); // Verify the tasks inputTask.Control(TaskAction.Verify); outputTask.Control(TaskAction.Verify); // Write data to each output channel FunctionGenerator fGen = new FunctionGenerator(/*Convert.ToString(frequencyNumeric)*/matrix_data[i].freq, Convert.ToString(samplesNumeric), Convert.ToString(Convert.ToDouble(frequencyNumeric) / (rateNumeric / samplesNumeric)), "Sine Wave", amplitudeNumeric.ToString()); output = fGen.Data; writer = new AnalogSingleChannelWriter(outputTask.Stream); writer.WriteMultiSample(false, output); // Officially start the task StartTask(); // Start reading as well inputCallback = new AsyncCallback(InputRead); reader = new AnalogSingleChannelReader(inputTask.Stream); //reader1 = new AnalogMultiChannelReader(inputTask.Stream); // Use SynchronizeCallbacks to specify that the object // marshals callbacks across threads appropriately. reader.SynchronizeCallbacks = true; outputTask.Done += new TaskDoneEventHandler(outputTask_Done); inputTask.Done += new TaskDoneEventHandler(inputTask_Done); reader.BeginReadMultiSample(Convert.ToInt32(samplesNumeric), inputCallback, inputTask); outputTask.Start(); inputTask.Start(); // Setup the Task Done event outputTask.WaitUntilDone(); inputTask.WaitUntilDone(); //lock (runningTask); } catch (Exception ex) { StopTask(); MessageBox.Show(ex.Message); } finally { inputTask.Dispose(); outputTask.Dispose(); cmd_start.Enabled = true; cmd_Stop.Enabled = false; } } } private void InputRead(IAsyncResult ar) { try { if (runningTask != null && runningTask == ar.AsyncState) { // Read the data double[] data = reader.EndReadMultiSample(ar); // Display the data for (int i = 0; i < inputDataTable.Rows.Count && i < data.Length; i++) { inputDataTable.Rows[i][0] = data[i]; WriteTextAsync(data[i].ToString(), tx, pass_freq); } for (int i = data.Length; i < inputDataTable.Rows.Count; i++) { inputDataTable.Rows[i][0] = DBNull.Value; } // Set up next callback reader.BeginReadMultiSample(Convert.ToInt32(samplesNumeric), inputCallback, inputTask); } } catch (Exception ex) { StopTask(); MessageBox.Show(ex.Message); } } static async void WriteTextAsync(string text, string Name, string freq) { // Set a variable to the My Documents path. //string mydocpath = Environment.GetFolderPath(Environment.SpecialFolder.MyDocuments); string mydocpath = @"E:\code\imp_main\daq_data\WriteData_" + Name +"_" + freq + ".csv"; // Write the text asynchronously to a new file named "WriteTextAsync.txt". using (StreamWriter outputFile = new StreamWriter(mydocpath, true)) { await outputFile.WriteAsync(text+'\n'); } }
with this code i have only last frequency saved to file
and i want to get 3 files with 3 frequencies as well
how i can each time get another frequency?
where i'm wrong in the code?
thanks for answers
05-30-2017 10:25 AM
Hi Arbo,
If you are expecting 3 different files but only getting one, it is likely that the WriteTextAsync function is only being called once.
Or it is possible that the function is in fact being called 3 times, but the data in the file is being overwritten each time and therefore you only see the data from that last frequency.
-Mitchell | NI
06-07-2017 03:00 AM
yes indeed , how i can open separate thread for saving data to file each time , and lock the counter till the all data is saved and unlock and increment to new frequency?
06-07-2017 03:01 AM
06-08-2017 08:35 AM
If you are trying to open a new thread for writing data to a file, I suggest you look at this article from MSDN:
https://msdn.microsoft.com/en-us/library/ck8bc5c6(v=vs.100).aspx
06-08-2017 09:22 AM
thanks
but this article more compatible for controls and forms using... that i need is to lock (for loop counter. this loop must wait until thread is ends his measurement and append data to file and after this will increment his value)
i saw interlocked.increment method but it very confusing , i did not understand it.
06-09-2017 01:01 PM
I should have asked this before, but what software, OS, and hardware are you using (please include software versions)?
06-09-2017 04:10 PM
Hi
i'm using Windows 7 64 bit, visual studio 2015, ni daq 15.0
hardware: intel core i5, 8gb ram
06-12-2017 11:00 AM
Are you using Measurement Studio?
06-12-2017 12:22 PM
no
i'm using clean visual studio 2015 with reference add-ons:
nationalinstrument.comon.dll and nationalinstrument daqmx.dll
